Question about Maclaurin series - calculus
andydan1060
Find the Maclaurin series of the function https://webwork.wustl.edu/webwork2_files/tmp/equations/87/63afd4b6f3566e2a90aa420dc5d1821.png
c_3 =
c_4 =
c_5 =
c_6 =
c_7 =
(8x^2)[(9x) - (9x)^3/3! + (9x)^5/5! - (9x)^7/7! + ...]
I got c_3 = 72, which is correct, and c_5 = (8x^2)[(9x^3)/3!] = 5832/3! (coefficient)
Apparently that's wrong and it's supposed to be -116640/(5!).
What did I do wrong? Thanks!
Are you not just muddling up which coefficient is which? If you've got 1/3! and the answer has 1/5! then those are different coefficients.
Isnt c4 supposed to be the coefficient of x^4 which is zero in this series?
c_3 =
It's supposed to be
c_4 =
c_5 =
c_6 =
c_7 =
I got c_3 = 72, which is correct, and c_4 = (8x^2)[(9x^3)/3!] = 5832/3! (coefficient)
It's supposed to be c_5, not c_4, sorry.
First, your coefficient should have a minus.
Second, why do you think your answer and the answer given are different? Just because they look different doesn't mean they are!
Likes Delta2
Well PeroK is right, doing the calculations it turns out that 5832/3!=116640/5!. However i wonder if your teacher wanted you to do this assignment by manually calculating up to the 7th derivative of 8x^2sin(9x) and evaluating the derivatives at 0.
I suspect that since we have the coefficient of ##x^5##, whoever gave the answer preferred to have ##5!## in the denominator.
