Question about Morin's time dilation explanation
73 replies · 6K views
PeroK said:
Yes. The light's velocity has a horizontal component because we deliberately chose a reference frame to give it that horizontal component.
The way we gave it a horizontal component was by having a moving emitter.
It seems that we are saying that the horizontal component of the velocity of light is v based on the velocity of the emitter.
The emitter isn't doing anything to the photons it's just emitting them upward and because the emitter has a horizontal velocity the upward emitting turns into a diagonal trajectory of photons.
I guess with this info and I can kind of "get it" but it seems a little like the trajectory of light is incidental in the theory and that the trajectory doesn't seem like a continuous stream of light but some photons that happened to get in the right place at the right time.
That will be true of anything, not just light. Read post #20 by @Nugatory and think about it carefully.
In my experience, many students struggle with the idea of more than one reference frame. In this case, you have a source of light, emitting light vertically (in the rest frame of the source). And that's it. The physics must be done in that reference frame - all other frames are invalid in some way. That seems to be the logic. Or, perhaps, even if you allow an alternative reference frame, the source remains at rest at emits light vertically in that frame.
Being able to consider a scenario in more than one reference frame is useful in classical physics. In SR it not only becomes vital, but it's what the theory is all about!!
If you don't see these things, then I guess it's tough.
Why should all trajectories of light travel at c when we just formed the trajectory with some random photons?
The emitter emits photons with a vertical component of velocity, but their horizontal component of velocity doesn't seem intrinsic to the light beam or the photons but extrinsic to the emitter and how it places them on the trajectory based on the emitters movement.
You should not be thinking of light as photons. Photons are a QM concept and this is the relativity forum, and you should not be trying to mix the two. For this discussion you should think of the light in the light clock as a short pulse of radiation that travels at ##c##.
That's because it isn't. It's an artifact of your choice of reference frame. As @Nugatory explained in post #20, this is not limited to light; it's true of anything.
Reply
It's just what I said. It's not easy for everyone to imagine the same scenario from two different reference frames.
Think about a ball that has been thrown vertically in the rest frame of a train, thus the ball has obviously zero horizontal motion and therefore zero horizontal momentum in the rest frame of the train.
But this ball certainly has horizontal momentum in any frame relative to which the train is moving.
Now you may be surprised, but also light (i.e. electromagnetic wave or photon) has momentum
https://en.wikipedia.org/wiki/Photon#Relativistic_energy_and_momentum
https://en.wikipedia.org/wiki/Radia...sure_from_momentum_of_an_electromagnetic_wave
In analogy to the ball, do you now understand why there must be some horizontal motion and momentum of light in the frame relative to which the light clock is moving?
Time for me to repost an animation that I first posted in 2015 at https://www.physicsforums.com/threads/how-does-light-slide-sideways.804112/post-5048516
Reply
So I can think of the light clock as emitting pulses of electromagnetic radiation and the clock emits a pulse of electromagnetic radiation traveling in a circle whos radius expands at c.
The larger v is the shorter the opposite side of the triangle and the longer it takes for the pulse to hit the mirror.
In the usual light clock scenario, the pulse of light is perfectly collimated so it only travels in a single direction, rather than expanding outward in a sphere. That, for example, is what the animation by @DrGreg shows.
Yes.
Reply
So I've been thinking by about this more in terms of an electromagnetic wave that travels at speed c.
If the clock emits a pulse then in the frame of the lab the pulse will only traverse vertically (##\sqrt {c^2 - v^2}## * 1 second) meters every second that elapses in the frame of the lab.
##\sqrt {c^2 - v^2} = c \sqrt {1 - \frac {v^2} {c^2}}##
The same vertical distance is traveled in ##\sqrt {1 - \frac {v^2} {c^2}}## seconds in the frame of the clock
Things are making more sense now.
Thanks for the help everyone.
An electromagnetic wave doesn't have a single well-defined "speed". There are at least three "speeds" associated with it that can be distinguished: phase velocity, group velocity, and signal velocity.
What you are actually describing in your post is just what I described earlier: a pulse of light that is perfectly collimated so it travels in a straight line, whose speed in vacuum will be ##c##. Of the three "speeds" above, signal velocity is the one that most closely corresponds to the speed of the pulse. But that is also the one that is least like any kind of "speed" you would associate with a wave.
Reply
So if I have a vertical laser light clock on a train and a light pulse of the laser goes vertically in its rest frame then in the ground frame where the clock is moving horizontally the light pulse will trace an angled path (not vertical) and the velocity along this angled path should be c also, is this correct?
Also the light stays in the tube but is something making the light beam go horizontally?
Did you look at the animation that @DrGreg posted? Doesn't it show exactly this?
Yes.
In the frame in which the tube is moving horizontally, the tube is, um, moving horizontally. That is what "makes" the light beam move horizontally.
Reply
PeterDonis said:
Did you look at the animation that @DrGreg posted? Doesn't it show exactly this?Yes.In the frame in which the tube is moving horizontally, the tube is, um, moving horizontally. That is what "makes" the light beam move horizontally.
Yes, that animation from Dr Greg was useful.
Regarding the last thing you said, something makes me wonder why light stays in a tube when it moves, what's to stop the light from hitting the sides of the tube when the tube moves?
Reply
  • Sad
Perhaps I should expand on why I put "make" in scare-quotes in my previous post just now.
You seem to be thinking that the light "wants" to move vertically in the frame in which the light clock is moving horizontally, so something has to "make" it go at an angle instead. That's not a good way to look at it.
The light's path in spacetime is invariant; that path is what is dictated by the physics of the problem. Looking at the light clock in different frames just means looking at the same invariant path in spacetime from different viewpoints. From the viewpoint of the frame in which the light clock is at rest, the spatial path of the light beam is vertical; from the viewpoint of the frame in which the light clock is moving horizontally, the spatial path of the light beam is at an angle. But both are viewpoints of the same path of the light beam in spacetime.
That means it is not possible for the light's path in the frame in which the light clock is moving horizontally to be anything other than what it is. Nothing needs to "make" it the way it is. It has to be the way it is, because that's what happens when you take the light's path in spacetime and project it into that particular frame. There is simply no room for it to be any other way. It's as if you looked at the same object from two different angles and then asked what "makes" it look different, as if changing your viewpoint meant something had to happen to the object. Nothing happens to the object when you change your viewpoint. And nothing happens to the light clock when you change frames.
Reply
Whether the tube moves depends on the choice of reference frame. Whether the light hits a tube wall is a frame independent fact. So the latter cannot depend on the former.
Reply
The deviation of the angle between the frames, you are talking about, is called aberration.
What you write was only valid in non-relativistic physics (Newton's theory of classical mechanics). Example:
Johann Georg von Soldner 1804 said:
Hopefully no one finds it problematic, that I treat a light ray almost as a ponderable body. That light rays possess all absolute properties of matter, can be seen at the phenomenon of aberration, which is only possible when light rays are really material. — And furthermore, we cannot think of things that exist and act on our senses, without having the properties of matter. —
Source:
https://en.wikisource.org/wiki/Tran...on_of_a_Light_Ray_from_its_Rectilinear_Motion
In special relativity, aberation works not only with classical particles, but also with EM waves. The reason is the relativity of simultaneity.
Assume, a horizontal electromagnetic wavefront of the vertical light crosses the horizontal x-axis. In the primed rest frame of the light clock, the left and right side of the wavefront cross the x'-axis simultaneously, that means
##\Delta t' = 0##.
With inverse LT and length contraction follows with reference to the unprimed frame, that the left and right side of the wavefront cross the x-axis with the following time difference:
##\Delta t = \gamma (\Delta t' + {v \over c^2} \Delta x') = \gamma (0 + {v \over c^2} \Delta x') = {v \over c^2}\Delta x##.
For small angles: When the right side of the wavefront crosses the x-axis, the left side has already moved further across the x-axis by
##\Delta d \approx c \Delta t = c {v \over c^2}\Delta x = {v \over c} \Delta x##.
That means the wavefront is tilted by
##\Delta d / \Delta x \approx v/c##.
In both frames, the Poynting vector ##\vec S = \vec E \times \vec H## is oriented perpendicular to the wavefront.
Reply
  • Skeptical
Source:
##\Delta t' = 0##.
Thanks for the info, I will need to study those equations.
The full Lorentz transform I find a little confusing, I don't fully understand the part where ##\frac {v} {c^2} \Delta x'## the units seem to check out but I'm not sure how that quantity is associated with time.
That term is due to the relativity of simultaneity. That's how it is associated with time.
Reply
It is simply how the Lorentz transformations work and mix space and time into spacetime and a necessity for keeping the speed of light invariant.
Reply
As others said, this is the (very important to understand) term for "relativity of simultaneity". In Morin's book you find it's derivation in chapter "1.3.1 Loss of simultaneity", paragraph "The 'rear clock ahead' effect".
In the light clock scenario, the left and right side of a wavefront reach a horizontal mirror simultaneously in the light clock's frame and not simultaneously in the lab frame.
If you use the complete Lorentz transformation, then all relevant effects are automatically covered.
  • length contraction
  • relativity of "same location"
  • time dilation
  • relativity of "same time"
##\require{color} x' = \color{blue}\gamma \color{black}(x\color{red}-vt\color{black})##
##t'= \color{green} \gamma \color{black}(t \color{orange}-\frac{v}{c^2}x\color{black})##
For comparison the non-relativistic Galilei transformation:
##x'=x-vt##
##t'=t##
Reply
So a light clock will still work in any inertial frame, but the path may look different depending on which inertial frame you're looking at it from.
A light clock will work if it is moving inertially. Or, to say the same thing in different words, it will work if it is at rest in an inertial frame.
The path will be different depending on what frame (inertial or otherwise) you use to describe it.
Reply
The spatial path may look different. The spacetime path will be the same.
Reply
Chenkel said:
So what is giving the light the horizontal movement in the lab?
The observer's motion relative to the lab.
If you're cruising in a jetliner and toss a ball upward so that it falls back down and lands in your hand, the ball moves up and down along a straight line. But imagine a distant observer on mountain top looking at you through a telescope. He sees the ball's trajectory to be a parabola. So what is the path of the ball? A straight line or a parabola? The answer is, "yes".
Reply
  1. From the light clock scenario, derive time dilation factor ##1/\gamma## and calculate ##\gamma=\frac{1}{\sqrt{1-v^2/c^2}}## with the Pythagorean theorem.
  2. Use this result and the standard twin paradox scenario to argue, that the length contraction factor must be ##1/\gamma##.
  3. Derive the Lorentz transformation from length contraction by using the following diagram.
Solve the shown equation for ##x'##:
$$x'=\gamma(x-vt) \ \ \ \ \ \ \ \ \ \ (1)$$With a symmetry argument, you get the inverse transformation:
$$x=\gamma(x'+vt')\ \ \ \ \ \ \ \ \ \ (2)$$Eliminate ##x'## between the two previous equations and then solve for ##t'## to get the time transformation:
$$t'=\gamma(t-\frac{v}{c^2}x)\ \ \ \ \ \ \ \ \ \ (3)$$With a symmetry argument, you get the inverse transformation:
$$t=\gamma(t'+\frac{v}{c^2}x')\ \ \ \ \ \ \ \ \ \ (4)$$
Effective learning is possible by not only reading, but if you also solve problems by yourself.
It is good, that you started using LaTeX for writing formulas in posting #1 of this thread.
I propose, that you try to derive step-by-step the above equation (3) from equations (1) and (2) while using ##\gamma=\frac{1}{\sqrt{1-v^2/c^2}}##.
Reply
  • Love
I tried to get equation 3 from 1 and 2:
##x' = \gamma (x - vt)##
##x = \gamma (x' + vt')##
##x = \gamma ( \gamma (x - vt) + vt')##
##\frac x \gamma = \gamma (x - vt) + vt'##
##vt' = \frac x \gamma - \gamma (x - vt)##
Something tells me I might be on the wrong track with my equations but I told you I would try to solve the problem you proposed to me.
