How Do You Calculate the Number of Steps in a Random Walk?
In a discussion about calculating steps in a random walk, participants clarify that the total distance traveled is not simply the product of steps and step length due to the nature of randomness. The original equation presented, L = N^(1/2) * l, is debated, with a suggestion that it should be L = N * l for total distance. However, the concept of displacement versus total distance is emphasized, noting that while total distance can be calculated straightforwardly, displacement may average to zero. The conversation concludes with the realization that the original formula was correct, and the focus shifted to solving for N based on the relationship between distance and time. Understanding the distinction between total distance and displacement is crucial in random walk calculations.
leonne
Question about "random walk"
.. Recall that in a random walk where each step
has length l, the total distance traveled after N steps is L = N1/2l
My problem is the N number of steps, not sure how i would find that.
I saw in the book saying N1/2=\tau\lambda( its subscript lambda idk why always looks so weird)
I thought its the same as \tau which i found a formula l/v
but when i plug into the formula to find L i get (cm)(s) as units, which i don't think its right.
edit
ok reading my notes, it said soothing about, each step takes time \tau I found the time its the l/v , but not sure what to do next
any help thanks
first, is your initial equation right. L= N^(1/2) * l ? That doesn't make sense. I think that should be L = N * l, i.e. if you take 3 steps of 5 units each step, the total distance traveled is 15 units.
You and the original poster are forgetting about randomness here. At each time the step might be step forward, but it might also be backward. If the walk starts at the origin the mean will always be zero. The standard deviation won't be zero. This grows as the square root of N, the number of steps.
right, but I was thinking more along the lines of total distance traveled, as in if you walk a mile one way and then come back on the same path, the total distance traveled is two miles, but the total displacement, if you will, is 0. I thought the former is what he was asking about. But I guess it depends on what your trying to define.
yeah thxs for the help i figured it out. We where told the L~R so we just solve for N. I thought we had to find L. then plug N into this other formula to find the time. And the original formal i had is right
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
