Does Light Reach Objects Moving at High Speeds?
themaster1j
As I just registered as a member, I don't know if this question has been asked before on this forum, and I'm sorry if I'm asking it again.
From what I understand, even if an object is moving away from light with a significant speed, the light would still approach that object as if it would be standing still.
If an object travels at 50% of the speed of light and a light beam is emitted at ~300,000km behind that object, how can the light reach the object in 1 second if the object is moving away from the light? Doesn't it mean that the distance the light would have to travel would be more than 300,000km?
I apologize for my basic understanding of Physics.
Well for the object with speed 50% of speed of light time will increase will increase by the formula t=t0/(sqrt(1-(v/c)^2)), where t0 is original time.Similar way is for distance.The distance from your frame will have increased so that light cover's only 300000 km in one second.
Read about Lorentz trans formation. Speed of light is postulated to be constant by relativity because of causality. Lorentz transformation is what makes speed of light constant.
Last but not least, welcome to PF!
In the frame where the object is moving away, it does takes more than one second. In fact you can write
x1 = -3e8 m + 3e8(m/s) * t
x2 = 1.5e8 (m/s) *t
and solve for the value of time at which x1 = x2 as t=2
However, it is still true that if you transform to the frame of the moving object, so that it is standing still, the light beam still approaches it at 'c'. You have to be careful how you analzye this, becuase the notion of simultaneity is the moving frame is different - specifically, the coordinates of the object (t=0, x=-3e8 meters) transform to something like (t=.5*gamma seconds, x = -3e8*gamma meters), where gamma 2/sqrt(3).
This is done via the Lorentz transform
<br /> x&#039; = \gamma \left( x - v\,t\right)<br />
<br /> t&#039; = \gamma \left( t - \frac{v}{c^2} \, x\right)<br />
So the distance the light has to travel to reach the object doesn't increase, even though the object is moving away from the light?
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
