Question about the resistor value
  • Thread starter Thread starter anita1984
    Resistor Value
The ideal resistor value for a 3V laser module at 45mA with a 3.3V power supply is calculated as 6.6 ohms, but this setup poses risks if the supply voltage fluctuates. A slight increase in voltage can significantly raise the current, potentially damaging the laser diode. It's recommended to use a constant current source for safety and to avoid exceeding the diode's ratings. Starting with a variable voltage and a fixed resistor in series allows for gradual adjustments until the laser activates, indicated by a noticeable change in light output. For visible lasers, this change is apparent, while for infrared lasers, determining optimal current levels may be more challenging.
anita1984
Hello Forum ,
I would like to ask you about the resistor value ideal for a laser module 3V @45mA and the power supply is 3.3V , R= (3.3-3)/45= 6.6 ohm ? it sounds a little strange to me.
Have a nice day and thank you in advance.
yes, that's one of the reasons why you need supply power to a laser diode using a constant current source.
It seems risky to have the power supply voltage so close to the laser voltage, though, unless you are sure it isn't going to change.
For example, if the voltage went up to 3.6 Volts, the current would go up to 90 mA. That is double the current for a 9% increase in voltage.
I read up on this a little and it seems you should start with a variable voltage and a fixed resistor in series and gradually increase the supply voltage until the laser starts "lasering".
No idea what that means but I guess it is an obvious change in the light output.
The article I read suggested a 0 to 10 volt supply and a 100 ohm resistor in series, but with a current meter in circuit to see that you don't exceed the laser diode ratings.
If it is a visible laser, you should see a change in behaviour, but if it is infra red, I don't know how you would tell where the best current was.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
