Question about universal gravitation
To determine the total energy of the rocket booster, kinetic and potential energy should be calculated using the formula for total mechanical energy. The total mechanical energy will indicate whether the booster will return to Earth; a positive value suggests it will not return, while a negative value indicates it will. Additionally, comparing the booster’s speed to the escape velocity at its altitude can also provide insight into its trajectory. The discussion emphasizes the importance of calculating total mechanical energy to assess the booster’s fate. Understanding these concepts is crucial for solving the problem effectively.
Hannahj1
A piece of an empty rocket booster fuel tank (mass 45 kg) is ejected from a rocket that is 2100 km above the Earth's surface. It is traveling upwards at 4.5km/s at this time.
a) what is the total energy of the booster at this time?
b) Will it return to earth?
Total mechanical energy = ½mv^2 - GMm / r
for a, should i use kinetic and potential energy and plug in values? like find the total mechanical energy
and for b, you find the total mechanical energy if you didnt have to do that for a, then if the value is positive it won't return to Earth but if its negative, it will.
Hi Hannahj1, Welcome to Physics Forums!
Yes, it looks like they're looking for the total mechanical energy in part (a).
Yes, the total mechanical energy is diagnostic of whether or not a given orbit is bound or unbound, as you've stated.
You also have the option of determining the escape velocity at the given distance and comparing it to the booster's speed.
Likes Hannahj1
Are you saying that, if your answer to a is positive, it won't return and if your answer to a is negative, it will?
Chet
thank you so much!
