- 50,514
- 26,562
Jilang said:Are the paths real at all given that only one could ever be observed?
No, no path is observed for virtual particles that are internal lines in Feynman diagrams.
TrickyDicky said:But they have a different kind of effects, let's call them virtual effects from virtual fields,(like say the line separation in the Lamb shift or the pressure in the Casimir effect), what makes these less real than clicks in a counter, or in the latter case the object that "causes" the click less of a math artifact?
Simply, since it's being claimed that internal lines of Feynman diagrams are mathematical artifacts I just showed a couple of elementary particles of the SM that are always internal lines and that are considered real indirectly by their effects(look up jets and hadronization). Why effects like electric repulsion, spectral line separation or Casimir force don't deserve the same treatment is what I was asking, but the best answerso far is by bhobba:just because.ddd123 said:Can you expand on this? Thanks.
Hmmm, all the answers to the OP and ddd123 rest on the idea that something "doesn't exist", period. That looks pretty ontological to me. So your answer is reasonable but doesn't seem to correspond to what is being argued here by most. All the claims have been clearly ontological.PeterDonis said:The words "virtual" and "real" in this connection (i.e., referring to internal vs. external lines in Feynman diagrams) IMO are best viewed as technical terms; they're just labels attached to particular mathematical objects. No ontological claims are intended--or at least, using the terminology does not, IMO, require you to commit yourself to any ontological claims. If you don't like the words "virtual" and "real" because they seem to you to imply ontological claims, then just use different words (like "internal lines" vs. "external lines"). The math and the physical predictions are the same.
That's why I used the word "virtual field", more appropriate to a theory of quantum fields. But honestly, I don't think this is about semantics, it seems to be about ontology.The distinction between types of effects IMO is a question of what types of effects are reasonably called "particle" effects. A track in a cloud chamber seems like an obvious case of a "particle" effect. A shift in a spectral line or a tiny force between uncharged plates, not so much.
TrickyDicky said:all the answers to the OP and ddd123 rest on the idea that something "doesn't exist", period
Certainly not. But most, at least judging by the "official" position in this site will insist that any internal line in a Feynman diagram(other than those in the SM of elementary particles) doesn't really exist.ddd123 said:But does this mean that the former camp also believes that quarks and gluons don't really exist?
TrickyDicky said:That's why I used the word "virtual field", more appropriate to a theory of quantum fields.
TrickyDicky said:I just showed a couple of elementary particles of the SM that are always internal lines
Jilang said:If all the paths contribute, but none except one are not observed
I agree with this. I'm not arguing that "virtual particles" exist, rather that the distinction real vs virtual is basically arbitrary, so that if we decide the latter are mathematical artifacts this applies to the former too, and similarly if it is decided they have an ontological meaning.PeterDonis said:But the fields are either never "virtual" or always "virtual", depending on how you look at it. They are never directly observable (so always "virtual" in that sense).
I was actually referring to the appearance of the "virtual particles" effects when applying the name "virtual fields", in the sense that is not localized in the way dots in a screen are.The expansion in perturbation theory is an expansion of the amplitude in powers of the coupling constant, not powers of the field--the field doesn't even appear (so fields are never "virtual" in that sense).
You mean in the form of hadrons, I was obviously referring to single particles.PeterDonis said:This is not correct. The correct statement is that quarks and gluons are confined. But confinement does not prohibit you from looking at diagrams that have external quark or gluon lines. For example, the standard diagram for a weak interaction decay has external quark lines (the only internal line at lowest order is the W particle).
TrickyDicky said:You mean in the form of hadrons
TrickyDicky said:the distinction internal-external line is to a great extent arbitrary
This only shows again how arbitrary and removed from what is observed can diagrams be drawn.PeterDonis said:No; weak interaction decay diagrams don't show hadrons, they show quarks and leptons. The fact that the quarks involved are bound into hadrons is irrelevant to the diagram, because as far as the weak decay is concerned, the quarks do not behave like bound particles.
You probably know that the concept of on vs off the shell is not clear cut in many situations.Not really. An external line corresponds to a particle that is required to be on the mass shell. An internal line corresponds to a particle that can be off the mass shell--more precisely, it corresponds to an integral over a whole range of possible particles with momenta that are off shell.
TrickyDicky said:You probably know that the concept of on vs off the shell is not clear cut in many situations.
ddd123 said:How is this interpreted wrt, say, a hydrogen atom? The bound electron doesn't really exchange photons with the proton since they are off shell and are thus only mathematical artifacts?
Sure, any "real" particle is always slightly off shell as it is in its way between interactions, in this sense free particles are the ones that "don't exist".PeterDonis said:Can you give an example?
TrickyDicky said:any "real" particle is always slightly off shell
Gerinski said:In minute 38:00 of his lecture, Krauss says that over 90% of the mass of the proton is due to virtual particles.
Nick666 said:He actually says "over 90% of the proton mass comes from fluctuations in empty space"
Apparently you are missing my point. My point is that off-shell and on-shell is a convention of the formalism, and in that sense yes, external lines are defined as on-mass, no in-between case of ever slightly off-shell, and this is a practical formalism as it leads to calculations that result in good approximations to what is observed. But if one is going to make any ontological comment to this, like if that makes them real, or if they really exist or are math artifacts, one has to realize that the on-shell particle of the formalism is not "real" at all, and to be observed it must be considered as off-shell to some degree. Because the completely on-shell particle that appears in the formalism is an idealized entity that comes from infinity and goes to infinity, and you'll admit that what we detect has a finite source, detection and route between source and detection. So we come full circle and conclude that "real" particles are the actual mathematical artifacts which only function is approximate what happens in reality and the "virtual particle" perturbative corrections are what allow us to describe the finite interactions.PeterDonis said:No, it isn't. Off shell means it violates the energy-momentum relation. No real particle that's ever been observed does that.
TrickyDicky said:off-shell and on-shell is a convention of the formalism
TrickyDicky said:to be observed it must be considered as off-shell to some degree
TrickyDicky said:the completely on-shell particle that appears in the formalism is an idealized entity that comes from infinity and goes to infinity
TrickyDicky said:On-shell particles are defined by the formalism to be the ones we observe as dots,clicks, etc, if there can be anything more conventional you tell me.
TrickyDicky said:have you ever observed a photon on infinite route between asymptotic source and detector?
TrickyDicky said:What does S-matrix say in relation to interacting particles then in your opinion?
This would indeed lead to an interesting discussion. Not going to happen.PeterDonis said:So you think direct observables are "conventional"? That's a very...interesting...use of terminology.
Hmmmm, you are basing your point on direct observability and when I point out to you that you are not actually observing what you are claiming you observe you find it irrelevant, that's amusing.Irrelevant.
You do. You just don't realize it.Nobody claims that it means particles are only on-shell "at infinity" or that they can only be observed "at infinity".
