Question help local max and local min etc
  • Thread starter Thread starter nycmets718
    Local Max
nycmets718
For any constant c, define the function f-subscript c withe formula f-subscript c(x)= x^3 + 2x^2 + cx
a)graph y= f-subscript c(x) for these values of the parameter c: c = -1,0,1,2,3,4. What are the similarity and differences among the graphs, and how do the graphs change as the parameter increases?
b) For what values of the parameter c will f-subscript c have one local maximum and one local minimum? use calculus. As c increases, what happens to the distance between the local maximum and local minimum?
c)for what values of the parameter c will f-subscript c have no local maximum or local minimum?use calculus.
d)are there any values of the parameter c for which f-subscript c will have exactly one horizontal tangent line?
i need the answer to the questions to be explanations including what rules you used and any steps involved. really appreciate it thanks in advance.
Being a new member of this site, you might not have read the rules, particularly the ones about homework help. To see the rules, click the Rules button on the menu bar across the top of the page.
If you want help, you need to show that you have made a substantial effort first.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
