Question ιn Physics about moving magnets?
  • Thread starter Thread starter k90
    Magnets Physics
The discussion centers on a physics question regarding the interaction between two magnets, Alpha and Omega, with specific dimensions and a velocity of 100 km/h for Alpha. It is debated whether Omega can reduce Alpha's velocity or stop it completely upon contact. The consensus indicates that if the poles of the magnets are the same, repulsion could slow Alpha down, but the orientation of the magnets is crucial. To determine the outcome mathematically, additional information about the magnets' strength and mass is needed. The conversation highlights the importance of understanding magnetic interactions in physics.
k90
Hi, today i had exams in Physics and my Professor as an extra points question was asking the following question.
We have 2 magnets, one is named Alpha with dimensions 100 cm length, 70 cm width and 2 cm thickness (100x70x2) and the other one is named Omega (200x100x5).
Alpha is moving towards Omega with a velocity (u) of 100 km/hour and Omega is steady on the ground (u=0).
If Alpha which is moving, meet Omega which is steady on the ground, whould be possible Omega reduce the Velocity or even stop emmediately the moving of the magnet Alpha?
If yes why, and if not why...
Assume that the distance of the two surfaces when they meet (axisymmetric) will be 5 cm and also that are parallel to each other. The pole of Alpha is + and Omega - (or upside down, i think it does not matter).
Does anyone know the answer, is there any mathematical formula that i can use to find if Alpha will stop or not?
I would apprieciate if you could explain what is going on with this questio as no one of my friends knows the answer...
Thank you in Advance
hi there
welcome to PF :smile:
This useless info as it tells us nothing about the strength of the individual magnets
and that is why the specifics of the following cannot be answered ...
If Alpha which is moving, meet Omega which is steady on the ground, would be possible Omega reduce the Velocity or even stop immediately the moving of the magnet Alpha?
reduce the velocity, yes if the poles are the same ... there will be a repulsion
the orientation of the magnets IS important ...
what do you know about magnets and how they behave in the presence of other magnets ?Dave
Hi, thanks for your answer Dave,
I do not think that i remember or know further details, but let's assume that we can find everything that we need (i.e. mass, strength of the magnetic field) would be possible if the poles was the same, to stop emmediatelly the magnet Alpha? If yes how? if no why? is any Mathematical formula that i can "change" the numbers and see if this is possible?
Thank you for your observations.
Kind regards
Kostas
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
