Question involving capacitance.
  • Thread starter Thread starter allenli
    Capacitance
The discussion centers on a circuit involving a neon lamp with a threshold voltage for conduction and a capacitor that stores energy to flash the lamp. Given the values for capacitance, resistance, and voltage, the user calculates the energy released by the neon flash as 1.62x10^-4 J. To determine the time for this energy release, the conversation suggests focusing on the charging time of the capacitor rather than the discharge time, as the lamp has negligible resistance once ionized. The need for relevant equations to calculate the charging time is emphasized, indicating that this is crucial for comparing the energy emitted by the neon flash to that of a typical light bulb. The discussion highlights the importance of understanding capacitor behavior in relation to the neon lamp's operation.
allenli
A circuit uses a neon lamp. The neon lamp has a threshold voltage V0 for conduction, because no current flows until the neon gas in the tube is ionized by a sufficiently strong electric field. Once the threshold voltage is exceeded, the lamp has negligible resistance.
The capacitor stores electrical energy, which can be released to flash the lamp. Assume that C = 4.00×10^-8 F, R = 1.4200×10^6 Ω, V0 = 90.00 V and ε = 110.0 V.
The 110 V is connected to R and C in series and the neon lamp is in parallel with C.
Question: A typical light bulb emits at 100W. What is the ratio of energy emitted by the neon flash to the light bulb (Assuming the light bulb is turned on for the same amount of time as the neon bulb)?
Through my previous calculations I determined that the amount of energy released by a flash of light is 1.62x10^-4J. How do I attain time to answer the above question?
Hello Allen, and welcome to PF. Please do use the template. What previous calculations led you to 1.62x10-4 J ? (don't bother, I can tell).
Now, since the wording 'negligible resistance' doesn't help you in finding a discharge time for the capacitor, perhaps you are supposed to look at the charging time. That's where the 2.) relevant equations of the template comes in so nicely: do you have something at hand to calculate how long it takes to charge the capacitor from 0 ('negligible resistance' !) to V0 ?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
