Question involving conservation law and springs
The discussion revolves around a physics problem involving a freight car colliding with a spring-loaded bumper. The car's speed before impact is determined using the conservation of momentum, leading to a calculated speed of 10.9 m/s. The conversation also addresses the time taken for the car to come to rest after the collision, emphasizing the need to consider the spring's behavior and oscillation principles. The final calculations yield a spring constant of 7962.5 N/m and a period of 3.60 seconds, but the specific time for the car to stop is a quarter of this period. The participants clarify the concepts of momentum, energy conservation, and the nature of the collision throughout the discussion.
mizzy
A freight car of mass 1800kg is timed at 4.2m/s just after it runs into a spring-loaded bumper at the end of the track. The bumper consists of an 800kg mass that the car runs into, and a pair of large springs. The car travels 2.4m before coming to rest.
a)using an appropriate conservation law, find the speed of the freight car before it struck the bumper.
i'm not sure, conservation of momentum? or kinetic energy?
Before it struck the bumper, it's moving at a certain speed(unknown) at a given mass. hmmm...looking at what's given to find the initial speed we have to use conservation of momentum: m1v1 +m2v2 = 1800v1 + 800(4.2)
Does that look right? Can someone guide me please?
It is indeed conservation of linear momentum, but you are not applying it correctly.
You need to say Pbefore = Pafter.
Can you find expressions for Pbefore and Pafter?
ok. so p before = p after
m1v1 + m2v2 = m1v1 + m2v2
It's an elastic collision, right?
i calculated it and i got speed before = 10.9m/s
There's a second part to this asking for the time taken for the car to be brought to rest. do i have to consider the springs?? or can i just use kinematics equations
This equation is an identity. Since the terms on each side are the same it basically says 0 = 0. Can you show me how you got 10.9 m/s?
We will worry about the second part after it is certain that you got the first part correctly.
pbefore = pafter
m1v1 +m2v2 = m1v1 + m2v2
1800v1 = 1800 *4.2 +800v2
1800v1 = 7560 +800v2
using conservation of energy:
v1i - v2i = -v1f + v2f
v1i - 0 = -4.2 + v2f
solve for v2f. v2f = v1i + 4.2
1800v1 = 7560 + 800(v1i + 4.2)
1800v1 = 7560 + 800v1 + 3360
1000v1 = 10920
v1 = 10.9m/s
mizzy said:
pbefore = pafter
Picture the situation right after the collision: The car pushes on the bumper which pushes on the springs that get compressed until the car stops. If the car is moving initially at 4.2 m/s just after the collision, what do you think is the speed of the bumper?
energy is not conserved because the masses stick together and stay stuck. Besides, this is not an expression of energy conservation. What is the equation for kinetic energy? Check your textbook.
the speed of the bumper would b 4.2m/s?
This is an inelastic collision then?
m1v1 + m2v2 = (m1 + m2)v2
1800v1 = (1800 + 800) 4.2
v1 = 2600/1800
v1 = 1.44m/s
Yes.
Correct, but to avoid confusion, use one symbol to denote one and only one variable. Here v2 stands for the velocity of the bumper before the collision (which is zero) and for the common velocity of the masses after the collision (which is 4.2 m/s). This habit might get you in trouble in the future.
Correct.
v1 = 2600/1800
v1 = 1.44m/s
What happened to the "4.2" in the previous equation?
kuruman said:
Yes.
Correct.
ooops, i forgot to multiply 4.2. The answer i get is 6.01m/s.
Good. For the second part, you cannot use the kinematic equations because they are good for constant acceleration. Masses at the ends of springs do not experience constant acceleration. The quickest way to get the second part is energy conservation.
So using PEg + PEs + KE = PEg + PEs + KE
but we need to find time.
How do we do that?
How do we do that?
What fraction of the period T is the time that you are looking for?
I don't quite understand what you mean about what fraction? All i know is that the car travels 2.4m before coming to rest. Do i have to find the final velocity and find time from that?
When it comes to rest, does it remain at rest or is it instantaneously at rest and then goes back where it came from?
it goes back and forth since the bumper is attached to the spring
OK, in that case it has a period T which is the time required for a complete round trip. Here the masses go from the point of collision to maximum compression of the springs, which is not a round trip, just a piece (fraction) of it. What piece (fraction) of the period T then is the corresponding time it takes the masses to go from the point of collision to the maximum compression of the springs?
we want half of the period...is that right?
A period is the time for a round trip. Therefore
From maximum stretching of the springs to maximum compression it is ______ of a period. So ...
isnt' it half? because one period would be from stretch to compression to stretch...
sorry if I'm not catching on right away =(
Half a period is from maximum stretch to maximum compression. When the car hits the block, the springs are relaxed, not at maximum stretch. So ...
quarter?? ok...i'm guessing and that's not good
No reason to guess. Draw yourself a sine wave representing the motion of the masses over a complete period starting at zero displacement. You have one "mountain" and one "valley". Maximum compression is from the starting zero to the top of the mountain. What fraction of the total is that?
1/4th
Correct. Can you find the frequency of oscillations ω? If so how is it related to the period T?
omega = 2pi*f
therefore, f= omega/2pi
And how is f related to T? Also, can you find an expression for f in terms of the masses and the spring constant?
The inverse of the period is the frequency.
the expression for f with terms of masses and spring constant is
f = 1/2pi square root k/m
Good. Now can you put it together? Find what T is in terms of k, m and pi. The time that you are looking for is 1/4 of that.
k. T = 2pi square root m/k (k is equal to mg/x, where x is the distance of 2.4m?)
the question asks for the time is took the car to be brought to rest. So i know we came up with that the time is a quarter of the period and that is at max compression. so how is that when the car is at rest?
No. k = mg/x applies to vertical springs that stretch by amount x when weight mg is hung on them. The spring constant k should be given by the problem. If it is not, then you cannot find the period. Can you post the statement of the problem exactly as it is given?
What does maximum compression mean? It means that the mass has traveled as far in as possible. This means that it stops (instantaneously) because if it didn't, it would still move and you would not maximum compression.
  • #31
  • #32
And what are the questions that the problem asks?
  • #33
b)Find the time taken for the car to be brought to rest.
  • #34
OK. You can use energy conservation to find the spring constant k. You need to say that the mechanical energy immediately after the collision (when the spring is still uncompressed) is equal to the mechanical energy at maximum compression (when the masses are instantaneously at rest). This should give you k which you can then use to find the period.
  • #35
So...
PEs + KE = PEs + KE
0 +1/2mv^2 = 1/2kx^2 = 0
where v is the speed found from part a and x is the distance given before it comes to rest. Then find x and solve for T.
is that right?
  • #36
i'm sorry...the speed should be 4.2m/s because that is the speed right after collision.
I get a k of 7962.5N/m and therefore T = 3.60s
Can you confirm this?
THANKS FOR ALL YOUR HELP! =)
  • #37
Confirmed. Don't forget that 3.60 s is not the time you are looking for.
