Question on conservation of momentum
The discussion revolves around a physics problem involving the conservation of momentum as a woman jumps from a raft. The woman has a mass of 56 kg and the raft has a mass of 147 kg, both initially at rest. The key equation for momentum conservation is established, where the total momentum before and after the jump must equal zero. Participants emphasize the importance of understanding relative velocities, suggesting that the velocity of the woman relative to the water can be expressed in terms of her velocity relative to the raft and the raft's velocity relative to the water. The conversation highlights the need to clarify these relationships to solve for the woman's velocity relative to the water accurately.
lilmul123
A 56-kg woman contestant on a reality television show is at rest at the south end of a horizontal 147-kg raft that is floating in crocodile-infested waters. She and the raft are initially at rest. She needs to jump from the raft to a platform that is several meters off the north end of the raft. She takes a running start. When she reaches the north end of the raft she is running at 4.6 m/s relative to the raft. At that instant, what is her velocity relative to the water?
Psystem = Pwoman + Praft = 0
Pwoman(f) - Pwoman(i) + Praft(f) - Praft(i) = 0
I've split up the momentums into their each individual parts. The mass of the woman is 56kg, the raft is 147kg, and this is where I'm stuck. I believe that Pwoman(i) and Praft(i) are 0 because they both are initially at rest. Now I have Pwoman(f) + Praft(f) = 0. I don't know where to plug in her speed (Pwoman or Praft?), and either way, I would get a negative answer. Can someone help me figure out where to go from here?
Hi lilmul123! :smile:
In questions about relative velocities, you really need two subscripts, not one.
Call the woman j, the raft r, and the water w.
[STRIKE]Then Pjw, for example, would be the momentum of the woman relative to the water.
And Pjw = Pjr + Prw.[/STRIKE]
Then Vjw, for example, would be the velocity of the woman relative to the water.
And Vjw = Vjr + Vrw. :wink:
How do I figure out the speed of the raft relative to the water?
(On second thoughts, my last post was rather confusing when it talked about momentum, so I've edited it :redface:)
The question gives you Vjr.
So find a physics equation relating Vjw and Vrw,
and combine it with the geometry equation Vjw = Vjr + Vrw. :smile:
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
