Question on Diffraction Grating
The discussion revolves around solving a diffraction grating problem involving three bright fringes on either side of the central maximum with a wavelength of 490 nm. The user initially uses the equation d sin(theta) = m lambda / 2 but realizes the factor of 2 is incorrect for constructive interference. The maximum angle theta is clarified to be 90 degrees, as this represents the furthest displacement from the central maximum. The user confirms that m=3 is appropriate for the three visible fringes. Overall, the conversation helps clarify the correct approach to the problem and the understanding of the maximum angle in diffraction.
tigerguy
Hi - I'm trying a problem on diffraction grating, and I keep on getting stuck. Maybe someone can help me figure out the last step:
Three, and only three, bright fringes can be seen on either side of the central maximum when a grating is illuminated with light ( wavelegnth = 490 nm). What is the maximum number of lines/cm for the grating?
Basically, what I've done is that I'm using the equation d sin(theta) = m lambda / 2
I figure that because its constructive itnerefrence for 3 fringes, m=3, and the wavelength will equal the aforementioned number. I also know that N= 1/d. So, I'm trying to figure out the value of sin(), but I'm not really sure what theta would equal to. How would I figure that out?
Is my reasoning correct, or am I missing something critical to solving this problem? Thanks so much.
Where did that 2 come from?
Hint: What's the maximum value that theta can be?
Oh, the 2 shouldn't be there, because its constructive interference, not destructive. Does the m=3 make sense, too?
I'm not sure what the maximum value can be - would it be 90 degrees (pi/2), because that's the maximum value that sin can be?
Right.
Makes perfect sense to me.
Not because that angle gives the max value for sin (which it does), but because the greatest displacement from the central maximum will be at 90 degrees. (Any more than that and the light would have to go backwards.)
Great, I understand it now. Thanks so much!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
