Lim Y K
- 26
Why must a switch be at the live wire instead of the neutral wire?
The discussion centers on the critical safety reasons for placing electrical switches on the live wire rather than the neutral wire. It highlights that switching the live wire ensures that appliances are fully de-energized, reducing the risk of electric shock, especially in hazardous situations like wet environments. The UK regulations prohibit neutral switching, emphasizing that the live wire must be switched first to maintain safety. The conversation also touches on the implications of switched neutrals and the importance of grounding in electrical systems.
PREREQUISITESElectricians, electrical engineers, safety inspectors, and anyone involved in residential or commercial electrical installations will benefit from this discussion.
Take the classic example of an electric toaster and a person in a bathtub. If you turn off the wall outlet with a switch on the live wire, the person in the bathtub is (reasonably) safe. If you turn off the wall outlet with a switch on the neutral wire, the person in the bathtub is at risk.Lim Y K said:In what way does that make the appliance safe?
In addition, if the wall outlet had its switch break the neutral line and not the active, then every unoccupied socket even though switched to "off" would expose a dangerous voltage to the idle probing of inquisitive toddlers (and pets).Lim Y K said:Why must a switch be at the live wire instead of the neutral wire?
In the UK all domestic sockets must be fitted with shutters which prevent contact with the live (or neutral) supply unless there is a pin in the Earth socket. The idea that a socket is made safer from an inquisitive child's fingers by providing a switch which the same child can easily operate is ludicrous.NascentOxygen said:Notwithstanding the hazard, some countries, I understand, do allow wall outlets without an associated switch; you have to plug and unplug from a constantly "live" socket. So try to keep fingers clear!
The most basic hazard with electricity is providing an alternate path to ground. If you grab a grounded wire then your body is just part of the ground. If you grab a live wire then your body may form a path to ground. By switching on the live side you make most of the wiring grounded when it is off, and only a small part of the wiring is live. Thus if you grab a random section of wire you are less likely to have grabbed a live wire if the switch is on the live side.Lim Y K said:In what way does that make the appliance safe?
the simple answer is if the circuit is switched on the neutral, then when the circuit is 'OFF' the load is still "LIVE" (at mains voltage).Lim Y K said:In what way does that make the appliance safe?
mr166 said:BTW just because a wire is white that does not mean it is a neutral. Here in the US it is very common to have 220V wiring that has black and white hot wires. The black measures 110v to ground and the white measures 110v to ground. They are 180 degrees out of phase so you measure 220V across the black and white wires.
One of those countries is the US. Switched outlets are unusual.NascentOxygen said:Notwithstanding the hazard, some countries, I understand, do allow wall outlets without an associated switch; you have to plug and unplug from a constantly "live" socket. So try to keep fingers clear!
To compensate for this, some of the outlets like ones in a bathroom or laundry room (any room that could have water on the floor) have ground fault interrupters. Wiki article:insightful said:One of those countries is the US. Switched outlets are unusual.
sophiecentaur said:There was a time when some electrical equipment had internal fuses in both the live and the neutral lines. I can't think why that idea ever caught on. I have actually used such equipment which had been modded to eliminate the neutral fuse.
And what is the rationale behind that? If the two conductors are truly floating then 1. how does the fuse provide a protection against shock and 2. How does an extra fuse in series do a better job of overload protection? There must be some scenario that prompted double pole fusing but I can't think of one at this minute.nsaspook said:I know that US military ships use floating AC for power, there is no neutral wire so both wires (single phase) are 'HOT' and are fused.
My two cents:sophiecentaur said:And what is the rationale behind that? If the two conductors are truly floating then 1. how does the fuse provide a protection against shock and 2. How does an extra fuse in series do a better job of overload protection? There must be some scenario that prompted double pole fusing but I can't think of one at this minute.
Damage control? Never know which side of a circuit's going to be open to salt water?sophiecentaur said:rationale behind that?
The requirement ashore is the safety of human beings. So, inorder to prevent human-electrical accidents, the neutral is earthed. The priority is neither the safety of the machinery nor the continuous necessary operation of the machinery. But the scenario onboard ship is totally different. The priority is the continuous operation of the machineries which are classed "essential". The distribution system followed onboard is "insulated neutral" system. The main priority onboard is the safety of ship which includes navigation & fire safety..etc. If due to Earth fault, the machinery classed as"essential" gets isolated, say for eg: steering gear, then the safety of ship is at question, which may lead to collison, grounding, fire & pollution etc..So the priority onboard ship is to maintain the continuity of the supply to the machinery in the event of "single Earth fault occurring". Continues..
That sounds dangerous. Like the kind of thing where you might touch the spotlight with one hand and something correctly grounded with the other and get a serious shock.tfr000 said:Simple example... I once repaired a spotlight lamp in a garage. When you operated the switch, it would go from bright to dim instead of from on to off. I found that the switch had been wired into the neutral side. The lamp current was obviously finding another path to ground when the neutral was interrupted. I moved the switch to the hot side, problem solved.
FactChecker said:That sounds dangerous. Like the kind of thing where you might touch the spotlight with one hand and something correctly grounded with the other and get a serious shock.
CWatters said:
Alternating current travels in a circular path along the "hot" and the neutral conductor. The switch breaks the circuit in the hot.Lim Y K said:Why must a switch be at the live wire instead of the neutral wire?
where?mr166 said:WW you are 100% wrong.
