Is the Proof of Uniqueness in Arnol'd's Vector Field Correct?
  • Thread starter Thread starter osnarf
    Proof
osnarf
The relevant equations:
(1) \dot{x} = v(x), x \in U
(2) \varphi = x0, t0 \in R x0\in U
Let x0 be a stationary point of a vector field v, so that v(x0) = 0. Then, as we now show, the solution of equation (1) satistying the initial condition (2) is unique, ie., if \varphi is any solution of (1) such that \varphi(t0) = x0, then \varphi(t)\equiv x0. There is no loss of generality in assuming that x0 = 0. Since the field v is differentiable and v(0) = 0, we have:
|v(x)| < k|x| for sufficiently small |x| =/= 0, where k > 0 is a positive constant.
Huh? i was good up until the inequality.
If somebody has the book, it is section 2.8 of the first chapter.
Apply the mean value theorem between x and 0.
*smacks self in head*
thanks
So the claim is that v is Lipschitz continuous on a neighbourhood of zero. Are you sure that v is merely assumed to be differentiable? I suspect that you need it to be C^1, i.e. its derivative must also be continuous. This is so because a differentiable function is Lipschitz iff its derivative is bounded, in which case the Lipschitz constant is the supremum of the absolute values of the derivatives. Any C^1 function is locally Lipschitz, but this need not hold for merely differentiable functions.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
