Question on Simple Harmonic Motion.
A 100g particle attached to a spring with a stiffness of 10 N/m is projected upwards at 2 m/s, prompting a discussion on its motion. The initial calculations attempted to find the distance to the equilibrium position and the time until the particle comes to rest, yielding results of 0.227 seconds and 0.2531 meters. However, it was pointed out that the particle is already at a new equilibrium position when hanging at rest, meaning the initial assumptions about motion were incorrect. The equations used for constant acceleration do not apply to simple harmonic motion, as the spring's force varies throughout the cycle. Clarification on the particle's position in the motion cycle is needed to properly analyze its behavior.
Wesc
A 100g particle hangs freely at rest on the end of a spring of stiffness 10N/m. If
the particle is projected upwards with a speed of 2m/s, find the time taken until
it first comes to rest and the distance travelled.
Well, there's F = -k.x and of course the classic F = ma .. and the normal linear motion equations? And the conservation of energy too I think...
Ok, well first off this is probably wrong because I suck at Simple Harmonic Motion, but this is what I did:
I started off by finding the distance between L0 and the equilibrium position, by using m.a = k.x ... and got x = (0.1)(9.8)/(10) =0.098.
Hence, I did the following:
(0.5)(k)(x^2) + (0.5)(m)(u^2) = (0.5)(m)(V^2) ... and got V to equal 2.2272 m/s.
Then, I assumed that normal motion would resume and used "v=u+at" and "(v^2-u^2)/2a = s" to calculate the rest. I obtained t = 0.227 s and s = 0.2531 m
There are no answers available for this question unfortunately, and I've an exam on this topic tomorrow, so I was hoping that someone on this that understands SHM could help me if I'm doing this wrong? Thank you.
You didn't need to do any of this. The first sentence says the mass "hangs freely at rest." This means that the spring has already been stretched to the new equilibrium position, and the mass is just sitting there.
These equations only apply to cases of constant acceleration. They don't apply to simple harmonic motion because the force exerted by the spring is constantly changing.
Take a look at the top diagram on http://hyperphysics.phy-astr.gsu.edu/hbase/shm.html. Based on the givens in this problem, where in the cycle is the particle initially? Is it at the top, the bottom, the middle, or somewhere else? Explain your reasoning for your answer.
But what do you think this speed you have calculated represents?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
