Question on thin film interference
The discussion revolves around calculating the number of interference fringes created by a thin film of paper between two glass slides. Using the formula delta x = L (wavelength/2t), the calculated distance between dark fringes is found to be 1.44 mm. Dividing the length of the glass slides (7.25 cm) by this distance yields approximately 50 fringes. However, there is a debate about whether to count the starting dark fringe, suggesting the total could be 51. The conclusion emphasizes the importance of understanding how to count the fringes correctly in relation to the pattern's starting point.
crosbykins
A piece of paper of thickness 15 * 10^-6 m is used to create an air wedge between 2 glass slides that are 7.25 cm long. If the wavelength of the light being used is 595 nm, how many interference fringes are counted across the entire pattern?
delta x = L ( wavelength/2t)
delta x = (.0725)[(595 * 10^-9)/(2)(15 * 10^-6)]
= 1.44*10^-3 m
*now i know the distance between the dark fringes so i can divide the length of the glass slides to find the number of fringes:
.0725/1.44*10^-3
= 50 fringes
***is this correct?*** if it's wrong, a step-by-step solution would be greatly appreciated
looks good to me. although i think it would be 51, because the pattern starts with a dark fringe, and then proceeds 50 dx's down the road before the last dark fringe. if you look at it like a fence, it takes 51 fence posts to hang 50 lengths of fence. the dx's are the lengths of fence and the dark fringes are the posts.
cheers
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
