What Are the Components of Vector Q?
  • Thread starter Thread starter sankalpmittal
    Vectors
The discussion revolves around finding the x and y components of vector Q given the components of vector P and the resultant vector P + Q. The values for vector P are established as 6 for both x and y components, while the resultant vector has components of 10 and 9. A simpler approach is suggested, where vector P is expressed as 6i + 6j, leading to the conclusion that vector Q must be 4i + 3j. The final components of vector Q are confirmed to be 4 and 3, emphasizing the importance of simplicity in problem-solving.
sankalpmittal
The x and y components of vector P have numerical values 6 and 6 , respectively , and that of P + Q have numerical values 10 and 9. What are the numerical values of x and y components of vector Q ?
Note this problem gave the following values :
|Px| = 6
|Py|=6
|P + Q| = 10 or 9
|Qx| = ? To find..
|Qy|=? To find...
|P + Q|2 = P2 + Q2
+2PQcosθ
Here |P| = P
|Q| = Q
( Px = Py = 6)
P2 = Px2 + Py2
P2 = 72
P = 6√2
|P + Q|2 = P2 + Q2
+2PQcosθ
Putting P= 6√2
and
|P + Q| = 10 (given)
and also |P + Q| = 9 (given)
I get two equations :
Q2 + 12√2 Qcosθ = 28
Q2 + 12√2 Qcosθ = 9
Now what ? How will I proceed ? :confused:
Thanks in advance... :smile:
Hi sankalpmittal :smile:
Why use such a long approach?? You can simply see that P vector is given as, \vec{P}=6i + 6j and \vec{P}+\vec{Q}= 10i + 9j, where i, j are unit vectors in the respective directions...So what would vector Q be?
The magnitude of x and y components of Q vector will be 4,3 ! That's what the answer given in the question booklet !
Thanks Infinitum ! :smile:
Moral : Keep things simple.. :redface:
Well, usually :wink:
