Levi Porter said:
Thanks for the great responses
You are very welcome
Levi Porter said:
I was just visualizing the Big Bang and thinking about the external forces required to create a flat universe. With my better understanding of the scientific meaning of the word "flat", I want to suggest or ask if it is appropriate to consider the Big Bang as an example of a "flat explosion."
Ah--- progress! Next step: there are actually
several technical meanings of "flat" which might be relevant here.
The exact solutions of the Einstein field equation most often used to illustrate how Hubble expansion and the "Big Bang" can be modeled in gtr are the
FRW dust models. These happen to be
conformally flat but not
Ricci flat.
In gtr,
Ricci curvature is the kind which is proportional to the
stress-energy tensor, which represents the density and momentum of any matter or nongravitational fields. Also, "dust" is short for
pressure-free perfect fluid, so these are matter-filled models. Once you know these items of information, it is obvious that the FRW dusts are not Ricci flat. The other kind of curvature (of spacetime) is called
Weyl curvature or
conformal curvature and is measured by the
Weyl curvature tensor. Together, the Ricci and Weyl tensors contain the same information as the
Riemann curvature tensor. The terms "Ricci flat", "conformally flat" and "flat", when applied to a spacetime model, just mean that respectively the Ricci, Weyl and Riemann tensor of the model vanish.
And then there is the issue of
spatial hyperslices orthogonal to the
world lines of the dust particles in these FRW models, or speaking informally "spaces at a (global, coordinate) time". (Not every
congruence of timelike curves, i.e. a family of non-intersecting world lines which fill up a spacetime model, admits a family of
orthogonal hyperslices; the congruence must be
irrotational.) These may or may not be "flat" in the sense of having vanishing
Riemann tensor when treated as
Riemannian three-manifolds. Neglecting \Lambda for simplicity
the FRW dusts come in three types, according to whether or not these hyperslices are locally S^3, \, E^3, \, H^3; these happen to expand and recollapse (first case) or to expand forever (second and third cases). Then, we can say that only the second features flat spatial hyperslices orthogonal to the world lines of the dust.
A bit complicated, perhaps --- but it sounds like you know enough to expect complications in cosmology!
So, er, one, two, three, several distinct uses of "flat" might be relevant. You can ask others here to clarify some of the technical terms I used if you are curious (or you can look at some cosmology textbooks--- I always hope someone who drops by PF will be so intrigued by what they find that they pick up a good textbook! ...color me bookish, I guess).
Levi Porter said:
I wasn't referring to gravity alone as a singular force that is applied for the containment of the universe. I was trying to find out what other forces are at work to contain the 3 dimensional universe and space/time without having it expand exponentially into infinite dimensions.
Sorry, you lost me there.
Levi Porter said:
No I wasn't. They do seem to have similarities. I was asking if there was a consensus to a general shape of the universe; i.e. flat sphere, disc, cube...?
Someone mentioned a possible interpretation of your post which hadn't occurred to me, that you might have thought that "flat" meant something like "squashed like a bug". If so, any "squashing flat" would entail
non-isotropic dynamics, whereas the FRW models are
homogeneous and isotropic (all directions are equivalent). If you really did mean "squashing", you will probably want to learn a bit about the
Kasner dust, another exact solution often used as a cosmological model (for pedagogical purposes).
Cube: imagine identifying opposite faces of a solid cube. Well, if you didn't grok that, first imagine identifying the endpoints of a line segment, to form a circle, then imagine identifying opposite edges of a square, to form a torus. Anyway, yet another complication: we can also consider
quotient manifolds formed from the FRW models by doing something like this with all the spatial hyperslices. So for example we could have an FRW dust with "locally flat spatial hyperslices" which each have the topology of a three-dimensional torus, S^1 \times S^1 \times S^1. And the slice corresponding to our own epoch might be bigger than the "observable universe", which would mean that we couldn't tell the difference. Or it might be small enought that we
could tell the difference, hence the proposal by Cornish and Weeks to look for evidence of "nontrivial topology" in the spatial hyperslices. As this discussion shows, it might be impossible in principle for cosmologists to nail down all the details, unless they are prepared to wait billions of years--- and maybe not even then. The universe is a really big place--- I think it's amazing that scientists sitting on this tiny blue pearl can say with justifiable confidence anything at all about it!
It often happens that a casual inquiry involves all kinds of subtle issues--- that certainly seems to have happened here! This can sometimes make it difficult to compose a suitable response to a newbie posting.
Levi Porter said:
I wonder if it's appropriate to say that the Earth is flat once again?
Don't follow, but many others here can help you. I think I'll bow out here, since it seems that I might be trying to pull you up to too high a level too quickly, which unfortunately can induce narcosis
(yeah, a mangled diving metaphor) And at this higher level you would find--- you guessed it, more complications!
