Questions about understanding circular motion & the forces involved
75 replies · 9K views
jbriggs444 said:
The space-craft is at rest in this frame, yes? In the Newtonian model, gravity is a real force in this frame, yes? The inertial force is the one holding the space-craft in place against the real force of gravity.
Edit: of course, we could adopt the GR model and consider that gravity is not a real force. But then the frame is inertial which goes against the claim that the frame is non-inertial.
A.T. said:
Assuming Newton's model of Gravity (real frame independent interaction force), you have to introduce an inertial force to make Newton's 2nd Law work in a free falling frame.
The only difficulty here is: how do you determine that there is a force of gravity? There is no experiment that you can do to measure the gravitational force.
If you were in a capsule being hurled around a centrifuge (unbeknownst to you), treating your non-inertial frame as inertial, you would have to postulate some force of unknown origin pulling things outward. You could measure these forces using a spring, for example.
If you were in a charged capsule being accelerated in the direction of an oppositely charged body and treating your non-inertial frame of reference as if it were inertial, you could do a local experiment and you would conclude that non-charged bodies moved differently than charged bodies so you would have to postulate mysterious forces that were like electrical forces except that they operated on non-charged bodies and acted differently, or not at all, on charged bodies.
But if the accelerating force is a locally uniform gravitational force (which you have no means of detecting if you treat your non-inertial frame as inertial) there is no need for additional forces in order to make Newton's laws of motion work in your free-falling frame of reference.
As far as GR is concerned, is this not just another way of looking at the principle of equivalence? Frames of reference accelerating in a locally uniform gravitational field do not require fictitious (inertial) forces in order to apply the laws of motion.
AM
Newton's law of universal gravitation tells you so.
If you don't use Newton's version of gravitation. That's what GR does, where the free falling frame is considered locally inertial.
Andrew Mason said:
??. But that is my point. One does not need to introduce inertial forces in order to make Newton's laws work in a non-inertial frame where the acceleration is caused by gravity.
If you have a frame that is experimentally indistinguishable from inertial, why are you calling it non-inertial?
Andrew Mason said:
How can the observer in the free-falling frame apply Newton's law of universal gravitation if he can't detect gravity?
If the frame is "non-inertial" due to gravity then you have stipulated that gravity exists whether it is detected or not. There's no sense quibbling about what you've already stipulated to.
In any case, a free falling observer can easily detect gravity. He looks around at the other free falling objects. [This does not count against the equivalence principle since such observations are non-local]
A.T. said:
By plugging numbers into the formula:
https://en.wikipedia.org/wiki/Newton's_law_of_universal_gravitation#Modern_form
As you see the force is independent of reference frame (observer).
Your means of determining the mass of the gravitating object is to use M = r^2g/G where r is the distance to the centre of mass of M and g is your acceleration toward the common centre of mass. But our premise is that the frame of reference of the spacecraft is treated as an inertial frame for applying the laws of physics, so it is not accelerating.
I think that all we can say is that inertial forces do not arise in a frame of reference that is undergoing gravitational free fall in a locally uniform gravitational field and that this is not the case with any other force. Why it is an exception is something that Einstein explores in the General Theory of Relativity. jbriggs asks the right question: "If you have a frame that is experimentally indistinguishable from inertial, why are you calling it non-inertial?"
AM
Andrew Mason said:
The force is independent of which inertial frame in which it is measured.
Newtonian gravity is independent of reference frame, regardless whether inertial or not.
That's the GR interpretation, not your premise under Newtonian gravity. Read you own post #26.
That would mean that acceleration measured in a noninertal frame will be the same as measured in an inertial frame...?
??The whole point is to apply the laws of physics in a noninrtial frame. If the body is undergoing constant acceleration due to gravity, one can apply Newton's laws without having to posit some non-Newtonian force.
AM
The acceleration measured in a non-inertial frame is different from the acceleration measured in an inertial frame. If one accepts Newton's second law, the net force in a non-inertial frame is different from the net force in an inertial frame. The delta is an inertial force associated with the choice of a non-inertial frame.
If you consider a freely falling frame to be non-inertial then Newtonian gravity is not that inertial force.
But that is not the situation that you are positing in post #26. You are positing an object that is NOT undergoing constant acceleration due to gravity. Rather, you are positing an object that is stationary in a "non-inertial frame" [your words] in spite of gravity. This demands some non-Newtonian force to keep it in place.
I agree.. One does not need to assume any non-Newtonian forces in order to make Newton's laws of motion work.
In post 26 I refer to a free-falling or orbiting spacecraft . Perhaps you mean some other post. If a body is stationary in the non-inertial frame of that spacecraft there is no need to posit any non-Newtonian force to keep it in place. That is all I am saying.
AM
No, it doesn't mean that.
AM
If we are working in the context of Newtonian gravity (not GR), then you determine that there is a force of gravity by looking outside the craft and observing the planet below. Then you deduce that you should be falling toward it but you are not, and therefore you have to postulate (in your frame a reference) an imaginary force keeping you from falling.
The difference between a spacecraft i) being hurled around in a centrifuge on the one hand and ii) being in gravitational orbit is that the observer can detect and measure the force (that the inertial observer views as centripetal) in i) but cannot measure that force in ii). In the case of i) he can measure tensions - i.e. the force required to keep an object stationary. In the second case, no force is required to keep an object stationary. We could suppose, for example that the gravitating mass is an invisible black hole or dark matter - ie. the observer would not be able to tell that he is subjected to a gravitational force. No inertial forces would have to be postulated in order to make Newton's laws of motion work in that frame of reference.
AM
AM
Well, if I would put Newton in the ISS, he would know that there is a face of gravity because of the presence of the planet, do you agree??
The situation is not different from being in a centrifuge. If I have a plumb line in a centrifuge, I know there is a tension force pulling one way and therefore I may invent the concept of centrifugal force to explain what happens. If I am in the space station, I know there is a force of gravity pulling one way and therefore I may invent a force to explain why objects seem to be floating around in my frame. You are saying that because I don't see anything physical acting on an object, because it is gravity which seems to act a distance (in Newtonian gravity), I can ignore it. I would think that Newton would have disagreed.
Newtonian inertial frames extend to infinity, and aren't limited by what some person can see. Newton's laws of motion do not hold throughout that frame, so it's not inertial.
Yes. But then he knows that he is accelerating and that defeats the premise (that he thinks of his non-inertial frame as inertial). You might as well use the example of a person in an accelerating car and say that he knows that the trees and buildings that are fixed to the Earth are passing by at an accelerated rate and must conclude that he is accelerating. The point is that he is not supposed to know what is actually happening. He is supposed to make Newton's laws of motion work in his frame of reference while being oblivious to the fact that his frame is non-inertial. To do that he has to invent an inertial force.
AM
Andrew Mason said:
The point is that...
Do you actually have a point, that goes beyond what the Equivalence Principle states? Because I don't think that anybody here argues against the EP, just against your confused description.
AM
I think you are missing the point about non inertial frames. How would you convince someone that he is accelerating? You say that you can just point out to the trees moving by with a relative acceleration and that shows that one is accelerating. But that is not the point! The person in the car could say "actually, I think it is the trees of that are accelerated past me, while I am at rest (or moving at constant velocity). Maybe I am in a huge hangar and my car is immobile while you are rolling past me a huge carpet with trees past me! *That* is the point: how does one disprove that? And the answer is that if one tries to apply Newton's laws, the only way to make it work is to introduce fictitious forces to make F =ma work in the frame of the car, and *this* is what shows that the car is accelerating, *not* that trees are accelerating by!
Now, in the case of the space shuttle, the situation is the same: one knows that there is a planet nearby (in order to make any statement about forces, one must be given information about the system in which one is. If you close the eyes of someone and give them no information whatsoever about their surroundings, there is no way to discuss anything regarding frames in classical physics). Now, given that there is a planet nearby, the person knows that he/she is attracted to it. So the only way to stay in orbit is to either introduce a fictitious force in the non inertial frame to make Newton's laws work or to realize that since the frame is non inertial, Newton's laws are not valid in that frame.
That is exactly what I have been saying. It is the experiments performed in the non-inertial frame that cause the non-inertial observer the posit fictitious forces.
The point is that if the acceleration is provided by gravity, all experiments show that Newton's laws work without fictitious forces. That really should not be controversial. That is all I am saying.
AM
Andrew Mason said:
That is exactly what I have been saying. It is the experiments performed in the non-inertial frame that cause the non-inertial observer the posit fictitious forces. The point is that if the acceleration is provided by gravity, all experiments show that Newton's laws work without fictitious forces. That really should not be controversial. That is all I am saying.
AM
And all I am saying is that if one looks out the window of the ISS and sees a huge planet there, and one knows about Newtonian gravity, and one notices that all the objects in the station are floating, one has to introduce a fictitious force to cancel the force of gravity (if one wants to apply Newton's laws using the station as the frame of reference). I don't see anything controversial in any of that.
Andrew Mason said:
Ok. So what experiment can he do to measure this mysterious force?
AM
One cannot directly. But that does not mean it is not there. Do you think that Newton in the ISS would have conclu
AM
One cannot directly. But that does not mean it is not there. Do you think that Newton in the ISS would have concluded that the force of gravity due to this huge planet suddenly disappeared because he is floating inside the station? This is what my first year novice students believe (the astronauts float because they are in space and therefore there is no gravity there!).
It sounds to me that you want to argue for the EP. As A.T. said, we all agree about that. I thought the question was about discussing fictitious forces in Newtonian physics.
The distinction that you are making seems to be that in the case of gravitational free fall the fictitious force is produced by an intellectual argument, whereas in the other cases it can actually be measured.
AM.
It's produced by the general rules of how inertial forces and inertial frames are defined in the Newtonian context. It's not different from other inertial forces.
And I disagree with that view. Fictitious forces can be directly measured in the non-inertial frame. The posited "anti-gravity" fictitious force cannot.
AM
Sure it can. Measure gravity, measure acceleration, deduce ficticious force. Easy. Easy enough for Newton.
It is the measurement of gravity in the non-inertial frame that is the problem. Gravity is measured by the acceleration it provides to a unit mass. In the non-inertial frame, there is no acceleration.
AM
Newton's universal law of gravitation can be deduced from within an accelerated reference frame. The result is a net inertial force of the form:
[tex]F=Km+\frac{GMm}{r^2}[/tex]
It is not difficult to distinguish between the constant term and the term which depends on gravity.
Though why you would chose to use a non-inertial frame which results in freely falling objects being unaccelerated in only one place is a mystery.
