Quick Conceptual Question on Lenz's Law
The discussion centers on Lenz's Law and the inherent properties of a coil that influence its ability to oppose changes in magnetic flux. Participants clarify that while current is generated in response to an external magnetic field, resistance is the true inherent property of the coil that determines the strength of this current. Resistance affects how much current can flow, thereby influencing the induced magnetic field. The conversation also touches on the misconception that resistance is influenced solely by environmental factors like temperature, emphasizing that it is a characteristic of the coil itself. Ultimately, resistance is identified as the key inherent property relevant to Lenz's Law.
longcatislong
A magnetic field is uniform throughout a region of space, but increases from 0 to 0.14 T in 2.4 s. A circular coil (of diameter 19 cm) is placed in a fixed orientation in this region such as to receive maximum flux. It takes 4171.91 turns to generate an emf of 6.9 V
What inherent property of the coil determines the degree to which it is able to fight the flux change, per Lenz's Law?a) curent
b) EMF
c) Resistance
d) induced magnetic field
I'm leaning toward saying that it's a) current. I know I dont' compeltley understand this yet, but I see nothing about inherent properties of coils in my book. All I've gleaned from my reading is that the current will always flow in the direction that opposes the change that caused it.
Can anyone confirm that I'm on the right track?
a) curent
b) EMF
c) Resistance
What happens to the coil to make it oppose the change in magnetic flux?
The coil? It makes a current that makes a field to oppose the external field...?
That's right. What affects the strength of the of the field the coil generates?
There probably won't be anything about "inherent properties of coils" in your book, but would you say the current in a piece of wire is an inherent property of it? A web definition of inherent says an inherent property is a "characteristic attribute".
So, the coil needs to generate a current in response to a changing external magnetic field. The current generated by the coil will in turn create an induced magnetic field. What affects the strength of the current/magentic field is the resistance of the coil... yes...?
I agree with that. Also note that the resistance is the only answer which is an inherent property of a coil. All the others depend on the environment you put the coil in.
Why is it exactly that the resistance is an inherent property of the coil, I would have thought that it would depend upon the temperature of the environment?
