Gravitational Force of a Point Particle Between Two Spherical Shells
  • Thread starter Ishida52134
  • Tags
    Gravitation
In summary, the problem involves a spherical shell with inner radius R1, outer radius R2, and mass M, with a point particle of mass m located a distance d from the center. The gravitational force exerted on the shell by the particle can be found using the equation F = -GMm/r^2, where r is the distance between the particle and the center of the shell. To find the force between two shells, one can use the concept of density and volume, but it is important to consider the two shell annuli separately.
Ishida52134
139
A spherical shell has inner radius R1, outer radius R2, and mass M, distributed uniformly
throughout the shell. The magnitude of the gravitational force exerted on the shell by a point
particle of mass m located a distance d from the center, outside the inner radius and inside the
outer radius, is
F = -GMm/r^2
I know that from gauss's law that the force from a spherical shell would have the same gravitational force as one from a point particle. How would you find the gravitational force of a particle located between two shells though?
any ideas
That's only true for points outside the shell. What is the force on a particle entirely inside the shell?
0. Oh do you just find the force and use density = m/v to substitute m with pv.
Then v = 4/3 pi r^3. Then u just subtract the total volume of the sphere by the volume of the sphere with distance d < the particle.
I'm not completely sure what you are saying there, but it doesn't sound quite right.
Think of the given shell annulus as made up of two shell annuli: one with outer radius d and one with inner radius d.
1. What is the gravitational force of a point particle between two spherical shells?
The gravitational force of a point particle between two spherical shells is the force exerted on the particle due to the gravitational attraction of the two shells. This force is calculated using Newton's Law of Gravitation, which states that the force is directly proportional to the masses of the two shells and inversely proportional to the square of the distance between them.
2. How is the gravitational force of a point particle between two spherical shells affected by the masses of the shells?
The gravitational force of a point particle between two spherical shells is directly proportional to the masses of the two shells. This means that as the masses of the shells increase, the gravitational force on the point particle also increases.
3. What is the relationship between the distance between the two spherical shells and the gravitational force on a point particle?
The gravitational force on a point particle between two spherical shells is inversely proportional to the square of the distance between the shells. This means that as the distance between the shells increases, the gravitational force on the point particle decreases.
4. Can the gravitational force of a point particle between two spherical shells be negative?
No, the gravitational force of a point particle between two spherical shells cannot be negative. This is because the force is always attractive and never repulsive. If the two shells have opposite charges, then the force may appear to be negative, but it is actually just the direction of the force that is reversed.
5. Are there any other factors that can affect the gravitational force of a point particle between two spherical shells?
Yes, in addition to the masses and distance between the shells, the gravitational force on a point particle can also be affected by the presence of other objects or sources of gravity in the surrounding area. However, these factors are typically negligible when considering the force between two spherical shells.
