Quick Michelson and Moorley question
  • Thread starter Thread starter Precepts
    Michelson
The discussion revolves around the Michelson-Morley experiment and the interpretation of light's speed in relation to the aether wind. A participant questions whether the resultant velocity of light should be treated as the hypotenuse in a vector analysis, given the right angle formed with the aether wind. Suggestions are made to consult additional sources or post a diagram for clarity. Understanding the definition of light's speed is emphasized as crucial for grasping the experiment's implications. Engaging in further discussion is encouraged to explore differing interpretations.
Precepts
This may be hard to express without a diagram. For the beam that split left and came back towards the half silvered mirror perpendicular to the aether wind, shouldn't it be solved that way vectorially? My textbook has the speed of light (c) as the hypotenuse. Which has screwed me over in the way I think of it. Shouldn't the resultant velocity be the hypotenuse as the wind and the light beam meet at a right angle?
Hi
Without seeing your diagram, I can't be sure. The best way to deal with your problem is to look at other sources of the same information - for instance this link. There is a triangle which appears to be along the same lines as the one you are querying.
This is a very popular problem to discuss so you are bound to find what you want by Googling.
Alternatively, you can try posting a diagram of your specific problem. Do whichever is easier for you.
I think before you can totally understand how a beam split itself, you should try to understand the definition of the speed of a beam (or a ray of light in the beam) if you can find one in any textbook.
If you cannot find one, try to define it by yourself. Your work will also help you to find out whether the speed of light in the second postulate of SR is referring to the speed of a photon in the ray or it is referring to the speed of the ray of light. One stone two birds.
I will like to discuss with you if your answer is different from mine.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
