Quick question about constant of motion
  • Thread starter Thread starter Gregg
    Constant Motion
Gregg
I have found that ##J = m r^2 \sin^2 \theta \dot{\phi}^2 ## is a constant of motion. How is this orbital angular momentum in the ##\theta = 0 ## direction? It is a particle moving in a central force field.
Shouldn't that be J = m r^2 \sin^2(\theta) \dot{\phi} ? I guess you should try to compare this to the "usual" definition, which is \mathbf{J} = \mathbf{r} \times \mathbf{p}
I can't work that out i can't do a cross product in polar coordinates.
## J = r p \sin (\theta) ##
## p = m r \dot{\phi} \sin (\theta) ## ?
## J = m r^2 \sin^2(\theta) \dot{\phi} ##
The cross product works exactly like with the usual rectangular coordinates. If you want to make it more straightforward, take the absolute value so you don't have to worry about sign conventions. If you are really worried, you can also transform back to rectangular coordinates but that's a ton of unneeded work.
Hi Gregg! :smile:
If you draw a "horizontal" circle, it has radius rsinθ, and the component of velocity parallel to the circle is φ'rsinθ :wink:
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
