I Quick question about explosions and displacement
Waves typically cause temporary displacement of atoms, returning them to their original position afterward. When a pressure wave from an explosion encounters a different gas with similar density, the displacement of that gas may be minimal. An explosion, such as a nuclear blast, can indeed affect nearby clouds, as observed in footage where the blast wave interacts with the smoke. The initial movement of the cloud is evident, but the extent of that movement is likely limited. Overall, while some displacement occurs, it may not be as significant as one might expect.
DarkBabylon
Understanding waves typically don't displace atoms but momentarily and then they move back into place, my intuition tells me that if a pressure wave on a certain gas meets a slightly different gas but with a similar density, the different gas wouldn't move dramatically due to the pressure wave.
Is this correct or am I missing something (except the obvious math) which will say otherwise?
Specifically, can an explosion, such as that from a nuke, move a cloud?
Looking at the behavior of the smoke in the first few seconds of the following clip, I'd say "yes". Watch what happens when the blast wave hits them.
Edit: To clarify, I think the cloud would move some, but not much.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
