Quick question about liquid crystals
  • Thread starter Thread starter skrat
    Crystals Liquid
The discussion centers on the order parameter S of liquid crystals as a function of temperature T, with participants noting that literature often lacks a specific formula for S(T). It is emphasized that the order parameter's expression varies based on the theoretical model and the specific liquid crystal system in question. There is no universal S(T) applicable to all liquid crystals, and experimental plots are more commonly available for different materials. References to Landau's theory of phase transitions and the Maier-Saupe approximation are mentioned as potential avenues for understanding the order parameter. Overall, obtaining an exact formula for S(T) requires experimental data and is dependent on the specific context of the liquid crystal being studied.
skrat
After some reading, I noticed that everybody likes to mention the order parameter and most of the literature simply adds a graph, for example: http://www.personal.kent.edu/~bisenyuk/liquidcrystals/maintypes2.html
However, many (all of them, to be exact) seem to avoid the exact expression of order parameter S as function of temperature T. This makes me wonder why?
I would like to know the exact ##S(T)##, so I can plot it in mathemathica and play with it. Where could I find this? :/
So you mean a theoretical formula for the order parameter versus temperature, right?
This will depend on the theoretical model and the specific system. And of course, on how this S is defined for the specific system.
There is no "exact" S(T) that applies to all liquid crystals.
It's more likely to find experimental plots for different materials.
Here you can find results obtained by using Landau's theory of phase transitions applied to liquid crystals (also called Landau-de Gennes in this case).
http://www.shu.ac.uk/research/meri/sites/shu.ac.uk/files/mmg-chapter_2.pdf
But the formula will depend on some parameters which have to be found experimentally.
What about Maier-Saupe approximation?
What about it?
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
