Quick Question - Explain Work Energy Concept
The discussion focuses on using the work-kinetic energy theorem to determine the force needed to accelerate an electron from rest to a specified speed over a given distance. Participants clarify that work is defined as the change in kinetic energy, which can be expressed through the equation W = Fx. The confusion arises from understanding why W must equal Fx when the kinetic energy formula K = 1/2 mv^2 provides the necessary information. Ultimately, the key takeaway is that while the kinetic energy can be calculated, the force is derived from the work-energy relationship. Understanding these concepts is crucial for solving the problem effectively.
physicsmarkb
[Solved] Quick Question - Explain Work Energy Concept
Use the work - kinetic energy theorem to find the force required to accelerate an electron (m = 9.11 x 10^-31 kg) from rest to a speed of 1.50 x 10^7 m/s in a distance of .0125 m.
W = Fx cos(theta), K = 1/2 mv^2
I know that I would set Fx cos(theta) = 1/2 mv^2 and then solve for F but I don't understand why I would do this.
Does anyone know why I have have to solve it like this?
work = the change in kinetic energy, in other words the final kinetic energy - the initial kinetic energy. The electron starts from rest and has no initial kinetic energy. That pretty much IS the work-energy theorem
Make sure you understand what work is, it's how much energy you're going to impart to the electron, and you know what final kinetic energy you would like the electron to have
So with K final, all you have is mass and velocity. With W = Fx, you have force and distance. Why do you divide mass and velocity by distance?
Edit: I just realized that you divide because you're trying to solve for F.
What I still don't understand is that why you have all the information for K = 1/2 mv^2 which is W = K but that doesn't work. I don't get why you have to set it equal to W = Fx.
Well with W=K and knowing K, you would've found work. Were you looking for work? No. Can you use the definition of work to find force? Yes. And that's what you did
Wow I'm so dumb. I can't believe I wasn't paying attention to W and F.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
