Quick question on accuracy (statistics)
To estimate the accuracy of measurements from multiple data sets, the standard deviation can be used as a measure of accuracy. The standard deviation of the mean is calculated by dividing the standard deviation of the data by the square root of the number of measurements. There are various ways to define accuracy, including using the distance from the mean or the root mean square. It's important to note that there isn't a single definition of accuracy, but using standard deviation is a common and acceptable approach. Understanding these concepts clarifies how to assess measurement accuracy effectively.
Elfrae
I've got nine sets of data (three people each took ten measurements of three different distances), and I need to find an estimate of the accuracy to which each person measured each distance.
I've already calculated the mean and standard deviation for each set of data, but I don't know how to estimate the accuracy. Someone mentioned using the root mean square but I'm not sure if this is correct. How do I go about this?
Look at the standard deviations of the means.
\sigma_{\mu_{x}} = \frac{\sigma_{x}}{\sqrt{N}}
I'm not sure I understand you. Are you saying that the standard deviation of the mean is the standard deviation of the data divided by root N? Is that the accuracy? I don't know what is meant by 'accuracy' in this context.
"Root mean square" is the standard deviation!
I think Courtigrad was under the impression that you wanted an "overall" accuracy for all three people, not three different accuracies.
Just as there are several different "averages" (mean, median, mode, midrange) so there are several different measures of accuracy or "dispersion".
The standard deviation is itself a perfectly good measure of "accuracy". Another is the "distance from the mean": Take the absolute value of the difference of each measurement and the mean. The "accuracy" is the largest of those: you are saying that the "true value" is the mean plus or minus that "accuracy".
So there is no one definition for 'accuracy' but using the standard deviation as a value for accuracy is acceptable?
Right, now I know what the question is asking! Thank you.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
