Quick Question about a Concentration Problem
  • Thread starter Thread starter Lori
    Concentration
The discussion revolves around understanding concentration and dissociation in solutions, particularly focusing on acetic acid and its behavior in water. It is clarified that acetic acid (CH3COOH) is a weak acid that partially dissociates, producing ions in a limited amount. The solubility of various compounds is also addressed, noting that BaSO4 is insoluble, while CaCl2 and NaNO3 are fully soluble, contributing to the total ion count in solution. The correct dissociation of CaCl2 is confirmed as producing three ions, two chloride ions and one calcium ion. Overall, the emphasis is on accurately calculating ion concentrations based on dissociation reactions.
Lori
M = n/1 L
I was wondering if the answer is 6E. I'm not too sure about what the question is asking but i do know that the more moles there are, the more concetration of ions there will be. So, E seems like the answer since it has more atoms in the compounds. Is my logic correct?[/B]
Hi,
Practically, (in P=atmospheric and T=25°C) the dissociations that you need to take into consideration (compare) are B and C. Methanol (D) does not dissociate and acetic acid (E) dissociates only partially in water. Finally, BaSO4 (A) is not soluble in water.
No need for Ksp here. At 1 mol/L you can safely assume both CaCl2 and NaNO3 to be fully soluble and BaSO4 to be not soluble at all. Then, it is just a matter of number of ions produced during dissociation (writing the dissociation reaction equation will help if you don't see it immediately).
CH3COOH is acetic acid (not an alcohol!). It definitely dissociates, but as it is a weak acid, only partially. Safe to assume no more than just few % will be dissociated (actually just a few tenths of a %).
Likes Lori
Sorry, my bad, of course acetic acid is not an alcohol.
Post #2 has been edited in order to be correct.
If I were to count the ions for CaCl2 would be be 3 ions? Because Cl disocciates into 2 ions
Three ions, yes. Not sure what you mean by "Cl dissociates into two ions". There ARE two moles of Cl- ions per each CaCl2 mole, there is no "Cl" (nor "Cl2" for that matter) that can dissociate.
Oh. How would the acetic acid work. i could the ions
English please.
Acetic acid dissociates according to the equation
CH3COOH ↔ CH3COO- + H+
but it dissociates only partially (it is an equilibrium reaction, judging from your other questions something you have probably not yet heard about).
