Quite Easy Question PLEASE HELP
  • Thread starter Thread starter kajicky
A father is seeking help with a math problem involving a train's motion, specifically calculating its maximum velocity. The problem states that the train travels 12 km with uniform acceleration over 9 km and deceleration over 3 km, taking a total of 20 minutes. Key points include the need for more information about the uniformity of deceleration and acceleration. The discussion suggests using equations of motion to solve for velocity but indicates that the problem may be complex. The conversation concludes that this type of question is more suited for a homework forum.
kajicky
Im a father trying to help my daughter with a Math problem.. And I am feeeling a little dumbfounded with this one.
This is a summary of the info she has
g=9.8m/s2
Point A to B is 12km
uniform acceleration 3/4 of Total distance
deceleration 1/4 of Total distance
Total Time 20mins
Whats the max velocity of the train?
I would apreciate if some could help me to solve this and teach me how to do it, Ill look like a genius to my daughter.
Kind Regards
Kai
You haven't given all the information. For example, if the deceleration isn't uniform then the velocity can go arbitrarily high.
g seems irrelevant.
have ds=ds1(9km)+ds2(3km), t1=20min-t2, assume v@0km=v@12km=0 & const. a1,a2.
d(v^2)=v@9^2-0^2=2.a1.ds1=2.a2.ds2 => a2=3a1
v@9-0=at=a1(20min-t2)=3a1.t2 => t2=5 => v@9=..
Not sure whether you'll actually be able to figure that out.. anyway, this belongs in the homework forum.
