Rabbit vs. Tortoise: A 100-m Race
  • Thread starter Thread starter huong03
    Race
In a 100-meter race between a rabbit and a tortoise, the tortoise moves at a constant speed of 10 cm/s, taking 1000 seconds to finish. The rabbit, after a 16-minute nap, accelerates at 0.15 m/s² and actually completes the race in approximately 996.5 seconds, winning despite the nap. The discussion also clarifies the correct formulas for average velocity and average speed, confirming their definitions. Additionally, if the rabbit had only napped for 15 minutes, a specific acceleration would be required for a tie. Overall, the rabbit's nap and acceleration strategy ultimately led to its victory.
huong03
1. A rabbit and a tortoise compete in a 100 meter race. The tortoise moves at a uniform speed of 10 cm/s. The rabbit took a nap for 16 minutes. After the rabbit wake up, he accelerates at a uniform rate of 0.15 m/s^2.
a) Draw a time vs. velocity of the motion of the tortoise and the rabbit? (I'm clueless!)
b) How long does it take for the tortoise to complete the race?
(It takes the tortoise 1000 seconds to win the 100 meter race, right?)
c) How far has the rabbit moved at this time?
d) Who won the race? The tortoise, right? but why?
e) If the rabbit had taken a 15 minutes nap instead, what is his required acceleration for the race to be tie?
2. Is the following formula right?
a) average velocity = (vector)/time
b) average speed = lmagnitudel/ time
Please help, thanks.
Use formula
s=ut+\frac{1}{2}at^2
s_{tortoise}=0.10t
s_{rabbit}=\left\{\begin{array}{cc}0,&amp;\mbox{if}\ t&lt;\ 960\ s\\<br /> \frac{1}{2}*0.15*(t-960)^2, &amp;\mbox{if}\ t\geq\ 960 s\end{array}\right
v_{tortoise}\frac{ds_{tortoise}}{dt}=0.10
v_{rabbit}=\frac{ds_{rabbit}}{dt}=0.075*(t-960)^2\ for\ t\ \geq\ 960 s
You have got your part (b) correct.
Substitute t=1000 s into the 3rd equation to get 120 m.
Substitute s_{rabbit}=100\ m \ to \ find \ the\ time\ t\ taken\ by\ the \ rabbit\\<br /> \ to\ reach\ 100\ m \ to\ get \ t=996.5 \ s.
Unfortunately, the rabbit won the race.
Part (d)
s_{rabbit}=\left\{\begin{array}{cc}0,&amp;\mbox{if}t&lt;\ 900 s\\ \frac{1}{2}*a*(t-900)^2, &amp; \mbox{if} t\geq\ 900 s\end{array}\right
Substitute t=1000 s, time taken by the tortoise to finish the race = time taken for tie to happen, and s=100 m to get the answer.
Convert anything into SI units first. Initial velocity, u, for the rabbit is 0 because it starts from rest.
Can't help you with the next question, not clear enough...
Mistake Correction
v_{rabbit}=\frac{ds_{rabbit}}{dt}=\frac{1}{2}*0.15*2*(t-960) = 0.15t-144\ for\ t\ \geq\ 960 s
The graph is attached.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
