Race car suspension Class
The discussion revolves around the intricacies of race car suspension design, particularly for stock cars and formula cars. Participants explore various technical aspects such as roll center, instant center, suspension geometry, and the effects of body roll on tire performance. The conversation includes both theoretical considerations and practical applications relevant to race car handling and performance.
  • One participant emphasizes the importance of understanding roll center height and its impact on weight distribution during cornering, noting that a lower roll center increases vertical loading on tires.
  • Another participant discusses the need for body roll to effectively transfer weight to outside tire contact patches, suggesting that improper weight transfer can lead to loss of grip.
  • Several participants propose various factors affecting suspension design, including kingpin inclination, scrub radius, camber, caster, and toe-out settings.
  • There are discussions about the significance of instant center width and how it influences roll center behavior during body roll, with some suggesting that a narrow instant center width can lead to more radical changes in tire loading.
  • One participant outlines a detailed approach to designing suspension mounting points, including specific measurements and angles that must be calculated to achieve desired performance characteristics.
  • Another participant expresses interest in exploring wheel rates and spring selection in future discussions, indicating a desire for deeper technical insights.
Participants generally agree on the importance of various suspension parameters and their effects on race car performance. However, there are multiple competing views on the optimal configurations and the implications of different design choices, leaving the discussion unresolved in certain areas.
Participants reference specific software tools and literature for suspension analysis, indicating that practical application may depend on access to these resources. Additionally, some discussions involve assumptions about vehicle design that may not apply universally across different race car types.
  • #571
If you are running a race track that could use the big bar soft spring set (BBSS) up...like half mile or longer track...then there would be some justification of having the Roll Center on the left side. The BBSS setup uses aero down force to plant the right front tire in a turn. You run super soft springs to lower the nose and seal off the sides to create downforce. With this set up if you have too much force on the right frtont tire you need to take some of it away by moving the RC to the left until you get the proper amount..tire temps and handling, lap times..etc...will tell you this.
On short tracks this is not a good idea as your top speed just is not there. So on short tracks you maintain the RC offset to the right as is discussed in previous pages on this post.
Because the BBSS set up is the current fad, everyone is going to it without understanding why it is used and where it is used. So copying a set up used by the hot dogs on a long track , and trying to make it work on a short track will have the following results.
Aero will not be enough to download the right front tire so instead of turning at corner entry it will push. Since you have not transferred enough rear weight and cross weight to the right front tire because the RC is biased to the left, the left front tire have a lot of front end weight staying there thru the middle of the corner. Since the left front spring is so weak it is not able to transfer weight to the right rear tire on corner exit. The car is loose off.
Add to this factor the Detroit locker variable and you end up chasing your tail at the track.
The plus side is the fact you got the weights where they should be so the basic package is there..
  • #572
heat cycle of the tire
Like I have said many times , it is all about tire, Tires, TIRES. The driver that makes them last longest and has something left at the end of the race should win..all other things being equal. So where do you find an edge? The days of tire softening should be gone..but I suspect a lot of you are doping the tires with softeners. I did it too and there are a lot of tricks doing this and it is dangerous as you can make them gumballs and deteriorate to the point the tire disintegrates..this discussion will not go into tire softening,
Heat cycle – commonly known as scuffs, scrubs, a heat cycled tire has been brought up to race temperature then permitted to cool. You want the rubber bonds to be stretched and heated then cool down and permitted to re-attach to each other in a controlled manner. Specifically, tire heat cycling means a new race tire is brought up to temperature, removed from the car and the valve stem core is removed, the tire is stored in a cool place , laid flat with not other tires stacked on it, and is given a minimum of 24 hours to relax and relink the bonds between the rubber molecules. Putting race tires through an easy initial heat cycle and then not running them for a minimum of 24 hours allows the rubber bonds to relink in a more uniform manner than they were originally manufactured. Heat cycling actually makes the tread compounds more consistent in strength and more resistant to losing their strength the next time they are used. It increases the life of the tire and you increase the number of total l heat cycles the tire has before the grip falls off.
You can do this at the track on tune and test day. Heat cycling can be done by installing a new set of tires on the car and running 10 to 15 minutes on the racetrack. You have to run easy laps, and build up speed as the session continues. Run slow lap times 5-10 seconds off your normal pace. Do not cause heat shock by spiking the tire temperatures by spinning, sliding or locking the tires. Drivers attempting to heat cycle tires in the morning for use a few hours later in the afternoon will not experience any benefits from the morning attempt at heat cycling. Heat cycling tires on Saturday means not using them again until the same time on Sunday.
One weird thing I ran into that caused me to build a tire heat cycle machine was an incident regarding tire stagger. The drill on tune and test day was to air the tires with nitrogen ( more on this later) measure the stagger ( outside diameter of each tire with a small tape measure deigned for this. The tries were hot lapped and when the car came in we immediately jack up t he car and remeasured the stagger. In one case the stagger was SMALLER than when the tire went out? How the heck did this happen..the danr thing shrank! It took a few days and many telephone calls but I found the answer. Seem that when the tire is manufactured, it is inflated after the last press mold operation. The post manufacturing inflator was operated by some college kid working over the summer and the tire was over inflated and permitted to cool and took a set that measured considerably higher diameter than normal so when he tire was heated up again, it snapped back to the proper nominal diameter. Well this got me to thinking of a better way to heat cycle the tires so I built a heat cycle machine. I’m out of beer so got to run..more on this tomorrow.
  • #573
Tire heat cycle machine
The problem with scrubbing in the tires is heat shock of spinning them coming off the corner. This is much more controlled method to run in the tires..takes about 20 minutes per tire, monitor the temps with an infra red pyrometer while it is running.
Just about everything on this machine came from McMaster - Carr , a huge mail order mill supply house in Cleveland. I got the motor from Grainger because they were local and i had to experiment to find the right H.P and pulley diameters...but air cylinder, pillow blocks, control valve, air regulator, and rollers, (from roller conveyor), are from McMaster - Carr, as did the later linear bearing for the tire truer.
The frame is 2 x 2 inch mild steel that is hinged to pivot up to load the inflated tire. The downward pressure is applied by large air cylinder hooked to air compressor. i have a directional valve to accutate the cylinder, up to remove tire , down to load tire slightly then i kick in the ac motor for rotation..once the tire is up to speed, i can crank in more downward pressure with the air regulator.This down force varies with front vs. rear tire..too much pressure makes the tire wobble so you have to read the surface tire temp via infra red pyrometer to get maximum heat over whole width and not load the tire to ridiculous load that can cause wobble. Most tires are pretty consistent so the down force is pretty much the same in spite of compounds.
i added a tire truing attachment to make the tires round to .010 inch after mounting. I also check run out of mounted tires and have found one out of 4 tires mounted by local tire guy or Hoosier / Goodyear tire trailer folks will be off as much as .060 inch. To fix this you simply break the bead and re-seating the tire and most come in around 0.020 inch when properly mounted...btw..there is a small witness line running around the border of the tire/wheel and you can take a set of dial calipers and measure this as well...( the above 0.060 inch run out correlated exactly with the witness line offset.
There are many other things we do when heat cycling the tires..logging thermal growth, change of stagger etc.,,,it does take a few dollars to build it ( $ 1200 in 2001 dollars) but i did this when we had a fat race budget running 4 state super late model series so the only expense i had recently was a v belt...
the tire shaver/ run out gage portion cost about $ 500. The end results are we get twice the tire life from a set of tires..without them falling off the tire grip scale...
  • #574
Aero Drag and Aero Downforce
Ok now that we have a pretty good idea about how the suspension works, let us look at one of the least considered and most misunderstood things that happens at a race car at speed- Aerodynamic Down force and Aerodynamic Drag.
A lot of this info is straight out of Chassis Engineering by Herb Adams..recommended reading for this class.
Waddell Wilson ( famous crew chief and engine builder ..won 22 Nascar races I think) once said “ Anytime the car is moving, your moving air” or something like that..he won Daytona 3 times so I will listen to him. Anytime the car is moving , it is literally pushing thru a very heavy curtain of air. Imagine a curtain that weights 14.7 pounds per square inch. If you think about it , at sea level , there is a 2000 pound column of air pressing on your body area that would smash small car. That 7 foot tall curtain covering that 6 foot wide bay window in the front room has 840 square inches of area. A similar wall of air would weight 11,760 pounds and it is only an inch thick per or simplistic calculations. That is a lot of weight to push thru. Now consider that when a car is moving the air pressure measured on the top of the car is going to be different than the bottom of the car. It is never equal in the real world. to be so would mean we have a perfectly symmetrical ( same on top and bottom) shaped car. If there is more LESS pressure on top of the car than the bottom of the car we have LIFT. This is not good. We want more air pressure on the top of the car to develop down force. The amount of down force we have is measured in Lbs. One more amazing thing- Down force changes with the speed of the car. In engineering terms the change in magnitude of down force is in proportion to the speed squared. Ifin we got 50 pounds of down force at 30 mph we got 200 pounds down force at 60 MPH. Now we know how down force is created. We increase the air pressure on top and recue it underneath the car..simple!
There are many formulas used to calculate down force. All the big dollar teams use wind tunnels that have wheel weight scales and gauges to measure Drag, wind velocity et al.
But..this is not necessarily a good thing. The wind tunnel is designed to move air into and around a stationary vehicle. But you don’t race in 185 mph wind, you race at 120 mph through relatively still air. It's a different set of dynamics between the two conditions. This is not exact science and all you can hope for is seeing relative improvement not exact data. Air moving through a wind tunnel has a significant amount of energy whereas still air on a racetrack or on the road has none. One pound of air displaces about 13.07 cubic feet of volume at sea level. If one pound of air is traveling 75 mph in a wind tunnel, it would have 110 pounds of inertia. There is approximately 20 pounds of air contained in the volume of the race car. That equates to 2,200 pounds of total inertia. Each molecule of air has a lot of force trying to keep it going in the flow direction. It will take a lot of force to change its direction and once you do change its direction, it will carry a lot of force trying to keep it going in the new direction. Compress that high-energy air between the car and the walls of the wind tunnel and you introduce more variables for which you can account. There are a number of things you can do to figure out Aero on your car that can yield many advantages...cheap...you can do this yourself. More on this in later posts.
Why bother with Aero stuff??
Please re-read post # 19 on page 2 of this Thread.
Let’s look at a 3000 pound door slammer with 50% front and 50% left side weight. If you know the tire performance curve from the
manufacturer charts weight (vertical load in static pound) vs. Traction (lateral load in lbs.) you can calculate the Cornering efficiency.
What do you do if you do not have the tire performance curve?
Option 1. Take a Swag and guess. Typical Corvette corners at .84gs, road race sedan like Tran Am - 1.15 Gs,
2800 pound Super Late Model door slammer on 10 inch slicks set up to turn left only -1.30 Gs.
Option 2. Measure your Cornering Force.
Cornering Force in Gs = F = ( m*v2 ) / R
the above formula did not translate well when I pasted it, it should read mas times velocity squared divided by R
from our cone killing days in SCCA Autocross..skid pad testing ,,go to parking lot, airport,,what ever, set up circle 210 feet in diameter ( this is a 1/4 mile circumference flat track),
drive around the circle as fast as you can without spinning out..
G = 1.225 x R / T squared
R= Radius of the turn in feet
T = Time in seconds to complete a 360 degree turn
We did this and came up with a lap time of 15.65 seconds. This when squared is 15.652 = 245. Working backwards we have 1.225 x 210 / 245 = 1.05 Gs
If we multiply the vehicle weight by the G force of 1.05 we get 3150, close to the figure we calculated using the tire performance chart. See chart 14-2
Lets look at what happens when we increase the Cornering Forge to 1.15 Gs.
1.15 = 1.225 x 210 / T squared or 1.15 = 257.25 / T2 or 257.25 / 1.15 = T squared which when square root is found = 14.95 lap time.
We will cover more on adding aero down force in later posts but let us look at the other Aero happening – Aerodynamic Drag.
Carroll Smith said a lot about this in Tune To Win (a must for serious racers). It takes horsepower to move a race car and the les s HP you use to take care of Aero Drag the more you have to out accelerate the other guy. The formula for Aero Drag in this discussion is - Fd = Drag in Lbs. = Drag Coefficient (Cd) x Frontal Area (surface area in feet squared) x Velocity in MPH squared x / 391 which does tell us the pounds of drag but we really need to know the horsepower required to overcome the drag so Drag HP = Cd x Frontal Area x Velocity squared
A typical grocery getter you see at the supermarket needs 20 HP to over come aero drag at 40 MPH but 160 HP to run 80 MPH. Our Formula car runs 140 MPH on a 150 HP engine so we have a lot smaller frontal area and better Cd. See attached chart and I am out of beer..to be continued.
good link to see trick aero stuff on a real race car ( without fenders)
http://insideracingtechnology.com/usgpbar.htm
http://www.circletrack.com/chassistech/ctrp_0609_short_track_aero_drag/viewall.htmlhttp://www.circletrack.com/ultimate...ace_cars_explained/viewall.html#ixzz2WMvQWMrw
  • #575
Bernoulli and Coanda
Bernoulli’s Theorem
The main formula used in the Aerodynamics department is Bernoulli’s Theorem. This can get confusing so I will attempt to simply it to the basics. It involves Pressure, Velocity of air in this case and Area of the surface that the Air is moving around. The Theorem states that the total amount of Pressure times the velocity times the Area one side of an object MUST total up to the same number around the other side of the object.
P1 x V1 x A1 = P2 x V2 x A2
Let’s look at the attachment showing flow around a round tube. Obviously, when the tube is stationary, we have equal pressure and velocity (none since it is not moving and air is still) and the Surface area is equal. Even if we hung the tube out of the window of the grocery getter at 30 MPH we still have equal numbers. Note the major turbulence and partial vacuum caused by the layers exiting the tube. This is Aero Drag and will be discussed more in later posts. Next, we look at a piece of strut used on formula car control arms. It is of the tear drop design that permits the air to re-attach to itself after flowing around the major width, thus greatly reducing DRAG (note the Cd is 10 times less that the round tube). Again we have equal numbers on both sides of the equation.
When we look at the cross section of a Formula Car front or rear wing designed for down force, see attached Jpeg, things get a little trickier. The fat teardrop on the right side is the leading edge. Air hits the wing generating a small degree of lift which immediately drops of on the top of the wing. Air rushes under the bottom of the wing and reconnects wit hair separated by the wing a few inches past the trailing edge ( left side of the sketch). Note a vacuum and turbulence just after the trailing edge. Now see photo attached. I measured three wings and all three had about an inch more length on the bottom side than the top. The beauty of this theorem is that both sides of the formula MUST equal out to the same number. We have air passing over two different surface areas. One is an inch longer than the other. The only things we can mess with to equal out the numbers are pressure and speed since the Area of each side is fixed. The air is going to have to travel faster on the bottom side to make up the difference ….and we have the same amount of “pressure” being applied to a surface that is an inch longer. So what happens when you have a given force applied over a larger area vs. being applied over a smaller area? In this case we have lower pressure on the bottom side than the top side of the wing. Down force!
Lesson here is this- On the top of wing or the race car we want lower speed ( relative to the bottom air speed) and high pressure and we want higher speed ( relative to the top of the wing/car ) and low pressure on the bottom side to create down force.
Coanda Effect
Henri Coanda built and flew the first jet powered air craft in 1910. Use that one at the next triva b.s. session! A moving stream of air in contact with a curved surface will tend to follow that curved surface rather than going in a straight line. If you take a small piece of paper 3” x 5” and hold it by the narrow end with both hands so the long end dangles and the paper forms a curve, take a deep breath and blow over the curve , the paper will LIFT..magic!
There is a real good article at www.formula1-dictionary.net and
http://www.terrycolon.com/1features/ber.html
Now there is a whole lot of stuff we could discuss here like attack angle, Aspect ratio, lift to drag ratio, pressure vector etc.. but this is a race car suspension class and not a tutorial for aerospace design and build so I gladly leave this to folks much more qualified than I to take over. What I will say is that these basic principles do apply to the weekend door slammer running only 70 MPH at the local bull ring so stick with me, racers.
  • #576
Front end down force
My college friend Bugsy, had a 350 cid Chevy Camaro. It was hopped up and the front end got very light at 120 MPH. This was because the front end generated 300 pounds of LIFT at 100 MPH. We didn’t know about this at the time and are very lucky that no cows were out where new were making a top end run that night..the sins of youth. When you generate lift that is 10 % of your total body weight, you have problems.
Let us review what aero is all about. Back to our grocery getter, stick your hand out the wind at speed. Keep the palm flat ( parallel to the ground). This is air flow flowing over and under your car. Now rotate your palm 90 degrees so your palm is perpendicular to the ground and the wind forces your hand backwards as the full impact of the air mass is hitting your palm. This is Drag. When you rotate the palm 45 degrees so the thumb it pointed up you experience lift. Rotating the palm so the thumb is 45 degrees down you experience down force.
Palm at 90 degrees, your hand has lots of resistance. The air pressure pushes it back. This is drag. Measured in pounds, total drag s a combination of the vehicle's frontal area, dynamic pressure (air density and velocity), and a shape factor that defines how slippery it is. The shape factor is a dimensionless numerical expression called the coefficient of drag (Cd). Think of Cd as an efficiency factor, like horsepower per cubic inch (hp/ci) is for engines.
Here is the real deal. Aero forces go up with the square of the speed, meaning that when you double the vehicle speed, you increase the total drag resistance by four times. That is bad but even worse is the fact that horsepower requirements to reach a given speed go up with the cube of velocity. At 200 mph it takes eight times as much power to push the car through the air as it does at 100 mph. We will address drag later on.
Just about all door slammers have natural positive lift. Older cars with blunt front ends generated a whole lot of lift. My 55 Chevy was very light at 100 MPH because air got underneath and pitched the nose up. Even modern, fuel-efficient, jelly bean cars have lift. Positive lift is bad. So if lift is bad, why don’t the automobile manufacturers remedy lift. To counter lift we have to add down force and the cheapest best way to do this is to add an air dam ( spoiler) to the front end. This adds cost and even worse, adds drag. Drag sucks fuel economy and now the fuel mileage dictated by the government is not met and the car is not legal. The car manufactures walk a tight rope and balance the fuel mileage with front end lift and since it is illegal to drive over 70 MPH in the US ( Texas may have higher speeds..don’t mess wif Texas) lift over 70 MPH is not in the mix. Down force cancels lift but increases drag. So what do you do?
I think it was Fredrick Taylor who said “Form follows Function”. Ifin you are running the 1/4 mile drag strip ( 1000 feet now a days, I guess) less drag is the priority. Ifin you plan on turning left you better put some down force in the car. Our Formula Car driver likes down force. Short track racers are just getting into the aero aspect and can benefit by improving the Aero on their car. If you race a pure stock class car made in the past 20 years, where the rules say no body modification, you probably will not be able to reduce drag much. Even if you took off the windshield wipers, antenna, and side mirrors and sculpted the door handles and taped off the grille, you would not improved things that much because the automobile company spent millions making the car slippery to meet the fuel mileage standards. In the case of a Sportsman class rear wheel drive V8 engine, you can add things that can also even reduce aero drag.
Three areas you can make major improvements to aero are the lower front nose, sides and top rear of the race car. We will cover the front end here and the rest later as I am almost out of beer.
Front nose- You can attain a small amount of aero by adding an Inch of rake to the ride height. Make the rocker panel an inch lower at the front than the rear portion. Less air wil go under the car .This will cause a low pressure area and we have down force. Adding a front spoiler will cause more down force. A Spoiler is really an air dam. You are basically stalling out the air in front of the air dam and what ever small amount of air that gets under the air dam is moving faster than the stalled air and we have a pressure differential. This is increased when we have a splitter. .
Front end splitters on a race car produce aerodynamic down force by creating difference in the air pressure on upper and lower side of the splitter when the car moves.
It is attached to the bottom of the front bumper and stays parallel to the ground.
Splitter is about 2x longer than the ground clearance to be effective. So if the bumper is 3 inches off the ground, the splitter needs to stick out 6 inches. They are dangerous, and illegal on street cars for obvious reasons. See link below and look up splitter for more info..gotta run..no more beer
http://www.formula1-dictionary.net/
  • #577
side skirts and rear spoilers
If you have an air dam ( spoiler) mounted on the nose correctly, you now have low pressure under the car. We want to keep it there. One technique is to mount side skirts to the rocker panels. The design of the car plays a vital role in the effectiveness of skirts. Ideally, one wants to obtain lower pressure under the car by either speeding up the flow or simply removing the air altogether. The latter is usually not done due to the sanctioning bodies rule on body components. . Skirts are used to block flow from entering or leaving the sides with the purpose to retain low pressure by sealing to the ground or aid flow speed by minimizing flow through the sides. . Lots of people think the skirts are there to keep the under car air from spilling out, but always remember that air flows from high pressure to low pressure. If you are generating down force from under the car then side skirts are a must.
The effectiveness of the skirts depends primarily on how close to the ground the lower edge can be maintained. That edge should be less than a .8 inch from the ground, otherwise the skirts' effectiveness diminishes rapidly as the gap increases. in 2012 NASCAR issued a technical bulletin to teams outlining the changes, right-side skirts now must have a minimum clearance of 4.5 inches, with a maximum clearance of 5 inches. Left-side skirts must have a minimum clearance of 5 inches with a maximum clearance of 5.5 inches. but remember we are talking about 200 mph speeds here and suspensions that pancake down with the tremendous down force generated by the aero stuff we are discussing.
There is another method to block high pressure air from spilling under the car at speed. You can stick vortex generators on the front bumper and a wall of spiraling air will block out the high pressure air from seeping under the car. Not for everyone but it is a proven technique.Rear Spoiler - A rear spoiler is a device attached to the car's upper rear surface (usually the trunk lid) with no gap between it and the bodywork. If it has a gap,it's considered a wing, which is far more complex. As its name implies, a spoiler's purpose is to "spoil" the fast, smooth,low-drag airflow coming off the roof. By sticking up into the airflow, a spoiler causes the airflow to detach and separate, reducing its velocity and creating a pressure rise that decreases the rear lift tendencies. Although a rear spoiler primarily adds down force, in some situations it can also decrease drag, depending on the spoiler's height, angle, and length of extension off the deck. The more vertical the spoiler's angle,the more the down force at the price of increased drag. Exact results vary per vehicle and can only be determined by cut-and-try testing, but some studies suggest that the most down force is achieved with a spoiler height that's about 8 percent of the car's wheelbase. That means about 8-9 inches for a 106-inch wheelbase. For any drag decrease, the spoiler height will usually have to be less than 1 inch, but up to 2 inches there is usually no drag penalty. Down force that they generate has been shown to increase with increasing angle (measured from the horizontal plane). A 60° rear spoiler causes a change of about −0.20 in the lift coefficient CL. Adding a rear spoiler helps delay the air separation of the air stream coming off the roof. When the air stream finally hits the non channeled air past the rear of the car we have turbulence and a dead zone that causes drag. The more we can delay the time the air finally detaches, the less aero drag we have. Look at the back of a semi tractor trailer next time you are on the highway. It is usually pretty dirty because the dead zone keeps all the yucky dirty water and crap swirling at the rear of the trailer instead of carrying it away. Studies have been made where vortex generators were glued to the trailers near the rear edge and mileage improved 3 to 5%, lights remained cleaner longer and the trailer handing was dramatically improved as it did not whip lash as bad. See Airtab pic...I may buy sum..
  • #578
Diffuser
Diffuser – the non tech answer. Ok think of a carburetor, more specifically the venturi portion. We all know that air coming into the throttle bore is accelerated as it moves thru t he venturi area. It is being forced to move thru a smaller ID and has to speed up (Bernoulli's law). A diffuser replicates this principle in that it scavenges high speed air rushing in under the car body ( the first suction point) , accelerates it until it hits the diffuser, then slows it down and eases it back to normal air speed thus creating down force and reducing aero drag. As air flows in from the front and sides of the flat bottom, its follows the flat floor until it reaches the diffuser. At this point we have a maximum suction peak. The air hits the expansion chamber, is slowed down until it reaches the same speed as the slower free stream of air passing around the outside of the car. It does this by providing an area for the air to expand and slow down. It reduces drag by not causing flow separation of the air stream at tunnel exit. It provides a degree of wake infill ( helps fill in the area behind the race car ) thus reducing drag.
This whole air flow thing got me to thinking if there was a way to merge the two streams together. I did not know it at the time but it had already been done. Next post - diffuser pumps.
The aft part of a car underbody is where a diffuser is usually located. It works by accelerating the velocity of the airflow underneath the car. The pressure under the car is affected by the diffuser so that it can expand back to ambient in the diffuser, as the car moves through the air. Since the pressure below the car is lower than on the side and above the car, down force is produced if implemented correctly.
The faster you go, the more down force you generated. Think of fast moving air ( being generated by the diffuser) and then slowed down at the rear creating a vacuum effect, sucking the flat body to the ground.
If we dump the exhaust header into the diffuser expansion chamber portion we can help extract the air from the rear of the car more effectively .The hot exhaust gasses produced effectively energies the airflow, ( heats up the air stream - think expanding) helping to raise the low pressure air .This fast moving air flow returning back to the ambient atmospheric pressure at the exit of the diffuser, reducing drag levels. Hot exhaust gases also aid in expansion, again aiding in the airflow speed transition between fast moving underbody air and slow moving ambient air. Resulting in higher vacuum effect, more down force and reduced drag.
FYI- a true flat bottomed car (one without a diffuser) will produce down force in and of itself when run in rake. Essentially the entire flat bottom becomes one large diffuser. It too has two suction peaks, one upon entrance, the second at the trailing edge of the flat under tray. A diffuser acts to enhance this underside suction, it acts like a pump, encouraging better flow under the car. One thing to note is that the rear wing interacts with the diffuser "driving" it. The proximity of the low pressure side of the rear wing encourages better flow through for the underbody.
I attached a photo of a diffuser. It is flipped bottom side up so you can see the strakes and get an idea of how the air is channelized and permitted to expand. I posted a photo of the old formula car and we are doing some tuft tests. We taped tufts of yarn onto the diffuser to see what kind of flow we had. We took two Sears shop vacuum cleaners and place the hoses above and below the diffuser. These babies tout the fact they are 175 MPH shop vacs and wear ear plugs ifin you are planning on extensive testing. We wanted to see exactly how the two air streams were interacting. I can only upload 3 photos at a time for each post so may take a couple of posts to cover this. My point is that you can get a pretty good idea of air flow in your garage without a lot of fancy equipment.
As you can see by the photo. we have air flowing out of the diffuser expansion tunnel and we have air flow coming off the top of the diffuser and interacting with the bottom portion of the bottom wing. We initially thought these two streams were acting independently. Further testing found these two streams were combining to a degree. We had to find an empirical way to measure the flow. We took a light weight piece of aluminum and made a hinge with racers tape. We used the tried and true dial indicator and now had a method to put a number on the whole activity. The plan was to measure the dial indicator with the bottom vac only, then the top vac only then with both running at the same time.
Top vac on - 0 reading - the air stream was flowing over the top of the piece
Bottom vac on - .300”
Both vacuums on 0.200”
I assume the air dropped because it attached itself to the top vac flow and was being pulled over the top of the aluminum piece. This was confirmed when we placed a taller post in the air stream and more tufts were flowing straight horizontal at a higher level than when only the top vac was running. Conclusion- air is like taffy and will combine and increase flow. We did a lot of flow testing at the race track with WD 40 and we were able to find dead zones. Good flow meant a straight oil stream. We noted these areas and did extensive tuft tests on the dead zones to improve the flow.
  • #579
Diffuser pump
Let us look at the above post # 575 specifically the attached illustration 50b. Note that after air passes over/ around an object and is not channeled to slowly transition back to ambient atmosphere as the tear drop design does in 50c, the two air flows will counter rotate in mini vortexes immediately behind the object causing drag. This is the situation when air comes in under the car at the front is accelerated and the decelerated and comes off the roof of the diffuser. Air flowing over the top of the diffuser comes off the bottom of the diffuser and we have this condition as noted in attached 50b.
At the same time we have air flowing over and under the bottom wing designed like 50c and has 10 times less Cd ( drag).
So if we took a mini wing designed like 50c and mounted it so it would pull air flow from the diffuser and attach it to the much better air flow from the rear bottom wing ( see 81 car pic and note the little wing thingie bolted on the end of the diffuser) ..we in theory would have a net gain of flow and a reduction in drag. This is what the diffuser pump does. It took a while to tuft test and find the best location and mounting angle. See the 2 x 4 with many holes drilled at different heights. We had to play with fore and aft spacing then attack angle. The results proved that the air flow was moved up and the flow was increased as our little dial force gage indicates. I have many more photos of the testing but only can upload three at a time. You get the idea. You can do a lot of things with two vacuum cleaners and some yarn.
  • #580
cheap telemetry
Couple of things to tie up aero discussion. I bought this little 3 PSI gage from McMaster Carr. You can get a good idea of pressure on car roof and at bottom of front air dam by plumbing this gage to these locations. Do not run vinyl tubing unless you can tape it down so it will not flop or vibrate when you are driving. You need a stretch of pavement so you can get speed up to around 50 to 60 MPH and be able to read the gage. Most race cars do not have speedometers so note your RPM on tachometer in high gear. It doesn't matter what the speed is as long as you can maintain it so you get a decent reading at the given RPM. You want to find out the low pressure on the bottom and the high pressure on top. Then you can make aero changes accordingly and re-measure the pressure difference to find out if you are improving it.
The little fluid force gage and actuator rod was used to measure front A-arm movement on track during tune and test. I had to mount a VCR to read the thing. Mounted the gage next to the tach so we could see where we were in the turn. Played the video back in slow motion. Hey..it was not precise but got what we were looking for.
  • #581
Mike, I race a crate latemodel on 1/4 to 3/8 dirt ovals. I see a lot of my competition using a 12" rear spoiler. I can get all the traction I need coming off. Am I missing the boat by using a 6"?
  • #582
Timaladd welcome. Usually we run taller rear spoilers to put some down force in the car at the end of the chute, not coming off the turn. If you suffer too much over steer ( too loose) going into the turn you may want to add some height on the rear spoiler. I think the size track you race is too short to get true aero advantage and too much spoiler may add way too much drag and hurt you. A lot of the tall wing thing is money see monkey do. So if you are hooking up ok all the way around the track, sounds like you are dialed in.
  • #583
Hi All,
I do not wish to highjack any present discussion here but I do have a quick question I would like to ask the more experienced ones amongst us here ...
For a start, I do apologize for the generalistic nature of the question but I'm really looking for a general feel of relationships in dampers.
My question is this ...
Whats the current ratio of damping force in compression compared to rebound?
I know this may lead to some discussion and may even warent a separate thread so again I aplogize if that's the case.
I know current trends, especially on road courses are for very stiff compression damping force with high gas pressures to further support the outer wheels/ tire in cornering but in comparison to rebound ... how much stiffer?
I'm particularly interested in touring car, formula cars ... on-road cars really.
Although. Does this ratio go more to 1 to 1 in off-road?
I have heard ratio's for on-road touring and super 8's as high as 8 or even 9 to 1 in compression to rebound. Compression being the stiffer/ stronger force ... is this true?
Thanks for any input.
Anthony
  • #584
Welcome Anthony...good question. I have only addresses this on post 217 page 13 briefly and is bares discussion. If memory serve me..dubious at my age..a typical passenger automobile uses single tube dampers ( shock absorbers to those in Dixie) . As the name implies this is a single tube mounted to the suspension component(usually lower A-Arm or control arm. It is filled with oil and a piston forces oil through an orifice as it moves up or down. The end of the piston rod is attached to the automobile body of chassis. There is equal force required to compress the shock and retract the shock ( rebound action). This is known as 50/50 valving so that the typical grocery getter can handle the normal bumps and pot holes the car will encounter.
For strictly drag racing application the front shocks of a rear wheel drag car will be 90/10 that is 90 percent " up" force ( takes a lot to compress the shock) to keep the car nose in the up position to give maximum weight transfer to the rear wheels. On some dirt race cars they run a left rear tie down shock that is biased to maximize the compression and make it very difficult to pull the piston back to neutral position. Please permit me to dig out my notes and I will get back with you in a day or two..at track testing now..
  • #585
Thanks Mike.
I really would appreciate your knoledge and input on this...
Anthony
  • #586
I had a long chat with Jim Stimola of SRP Engineering. He has years of rebuilding Indy car dampers, Nascar Shocks and is in my opinion the go to guy on shocks. Short answer on ration of compression to rebound..how high his the sky? There are just too many variables to make a blanket statement. And since shocks are one final step in fine tuning a chassis, the secret specific combination of compression and rebound for that chassis on that day given that particular tracks condition is a very close hold item.
Single tube shocks have one setting for compression and one setting for rebound. Rebuildable gas shocks like Penske have infinite setting on compression and rebound AND have a nitrogen reservoir that can be variable as well. The combination settings are darn near INFINITE! Add to this the fact that shocks have their own motion rate that may differ from t he springs mounting angle and thus a different motion rate and the permutations go up. So is it possible to have 9 to 1 ration on compression...sure is. Is this the hot set up for all touring sedans..no way. All I can say is we swear by Penske shocks and fine tuning is done every time we go to the track. To get to this point you must have the spring rate and ARB spot on and a gas shock can be pumped up or reduced to one spring rate setting ( add or reduce total spring rate by one increment). Hope this helps.
  • #587
I see. Well thank you Mike for putting yourself out to talk to Mr. Stimola of SRP.
I understand about these guys wanting to keep specific settings to themselves and I believe we all in racing do the fine tuning at the track...
What I was looking for was a more generalistic slant on compression-to-rebound ratio's.
The old way and unfortunately some still set their dampers this way was to have compression very soft and tune with rebound resulting in rebound damping becoming way too stiff.
More recently I know its been found that a stiffer compression relative to rebound gave better results in keeping the contact patch of the tire in good contact with the surface.
Gas pressures of 1/4 to a 1/3 of corner weight have also helped in supporting the outer tire in cornering for better road holding.
What I was wanting to try and find out was to what extent this ratio had changed. Specific settings do not interest me. If a certain team like to run their dampers on 7 low velocity comp' and 4 on rebound with 250 gas pressure does not interest me.
What I was looking for is in general terms how much this ratio has changed ... it would seam that teams and certain people think this might give too much info' away. Well that's too bad.
Thank you again Mike for asking and your work in this field and the effort you put into this thread is fantastic.
Anthony
  • #588
Anthony..thank you and if you like..send me a pm with specs on your car..weight, motion rate, spring / arb configuration..tires etc and I will send on toe Jim..may get more insite..
and better yet, if you want to post for all to see..would be good learning experience for those who follow this forum.
we call can learn..thats what its about..
  • #589
weight transfer when cornering
My original post on page 2 post 19 was from an old chassis set up class I took years ago. It never did go into detail on how we find the weight transferred during cornering. Was a rough estimate of metric chassis and spec tires etc..I did a lot of research after it was apparent that the figures were not as accurate as they could have been. But racing is about constant adjustment so here we go..
The purpose of this post is to find out two things.
1. The total amount of weight that is being transferred during cornering
2. 2. The amount of weight transferred to the front end during cornering.
It is pretty easy to find number 1 but a real bear to get to number two, Without going into too much detail, the former is straight math and the latter requires major calculations diagonal weight transferred because inertia and momentum in a turn.
We have a Spec Late Model stock car .Weight is 3111 pounds, 66”track, 103” wheel base. The race track rules state minimum crankshaft to pavement height is 10.5 inch. We have coil over shocks and small block Chevy with aluminum heads. Just how much weight is being transferred under cornering conditions?
Specs- total weight of vehicle 3111# and we scaled the car and found these Wheel weights -
LF= 777, RF= 747, LR= 1027, RR = 560
First thing to do is calculate the height of the Center of Gravity. We are not going to be super accurate in this drill as we want to find out a ball park figure of correct springs to use to get us in the game. When we measure the engine block we find the cam shaft is 4.5 inch above the crankshaft. So 10.5 inch minimum crank height plus 4.5 inch = 15 inch CG Height ( CGh).
Next we have to figure the circular acceleration of the track we intend to race.
From our cone killing days in SCCA Autocross. Skid pad testing ,,go to parking lot, airport, whatever, set up a circle 200 to 300 feet in diameter, drive around the circle as fast as you can without spinning out.
Alternative- go measure the local race track. Measure the width of the infield. I use an old Bushnell Yardage Pro range finder used in golfing to measure the distance; this will give you the diameter of the turn. Divide this by 2 to find the radius. Next hot lap session, use a stop watch and time the car from when it enters the turn to when it exists the turn.
G force = 1.225 x R / T squared
1.225 is a handy conversion factor
typical Corvette corners at .84gs and road race sedan like Tran Am 1.15 Gs. These were measured using skid pad testing. My guess is Late model purpose built stock car with 57% left side weight – 1.15 Gs1. The total amount of weight that is being transferred during cornering
Tw= Gs x car weight x CGh / track width
1.15Gs x 3111 x 15 / 66 = 813 total pounds transferred during cornering.
How good is this number? I looked at several recommended spring packages from various chassis books, chassis manufacturers, my chassis set up notes.
2800 to 3200 pound purpose built late model on 3/8 mile track 10 degree banking, recommended springs 350# LF, 350# RF, 220# ARB.
Initial impression is that we have 920 pounds of spring up front to counter the 498 pounds coming forward. Looking at it more in detail we have a coil over spring configuration mounted at 15 degrees. Looking at the attached illustration that 350 pound spring is really acting like a 191 pound spring. So we really have 191 + 191 + 220 (arb) or 602 pounds up front to counter the weight transfer.
The recommended coil over spring package in the rear was 225# and when you correct for the mount angle and the motion rate you have 94#. So by adding both rear wheel rates we get 94 + 94 + 602 = 790 pounds of resistance.
We calculated 813# above.
Weight Forward = Gs x car weight x CGh / Wheel base
WF = 1.15 x 3111 x 15 / 103 or 521 pounds transfer to the front of the car.
But we have a total front wheel rate of 602#..what gives??
We need to add the diagonal weight shifting to the right front tire when cornering.
We need to revisit the old high school trig book.
We have the 103 inch wheel base and the 66 inch track width. We have two sides of a Right triangle. The hypotenuse is 122 inch. ( ifin you can not figure out how to do this..go away).
We can find the angle of the hypotenuse intersecting the long leg at the right front tire location which is 33 degrees. Looking up the Degrees table the Sine of 33 degrees is .544
Diag wt = (Gs x Right Rear wheel weight x CGht / hypotenuse ) x sine A ( angle @ RF)
(1.15 x 1027 x 15”/ 122) x .544 = 79 pounds
79 + 521 = 600 pounds and our total front wheel rate of 602#..
Is this a perfect formula,,No. It is close enuff to get in the ball park on the spring package.
  • #590
Ranger Mike;
Thank you for this classroom undertaking. It has been extremely enlightening and, as if you read my mind, you went back and explained how the springs were calculated. I went through what was done early and had lots of questions. This answered those so well that I just went through your calculations for computing front springs using my road racing car. I did the calculations using 1.15Gs. The car weights 2897 lbs, with , 709 RF, 738 LR and 746 RR. The track is 64" both front and rear with a wheelbase of 96". The front bar rate is 355 lbs/degree and the rear is 271 lbs/degree. Springs are 700 lb front and 200 lb rear. The shocks on both ends are mounted at 9 degrees. The motion ratio in front is 0.765. The rear motion ratio is 1. Both the shock and bar are attached at the same place on both ends. In computing the cross weight since the car was a road race car, I averaged the rear weights and used that to figure the transfer. When I computed I arrived at a rate of 1006 lbs of resistance for the front and 594 lbs of weight transfer. If these calculations are good is the car too stiff in your opinion? Final question, do I do about the same thing to compute rear transfer only subtracting cross weight from the rear instead of adding? Appreciate your thoughts and thanks again for your work here.
  • #591
Well Thanks for the nice words, Smith. At first glance you have way to stiff springs and ARB. This is confirmed when i ran the numbers. A 2897 pound car with 64” track , 96” wheel base and I figured a Center of Gravity height of 16 inches. I came up with 832# total transfer. When you look at weight transfer coming forward I came up with 555 #.
1.15Gs x 2897# car x 16 “ CGht / 96” Wheel base = 555#
add to this the calculation of diagonal weight transferred. Our triangle is 64/96 = Tan A which is the angle of intersection at the right front contact patch. This is 34 degrees and the Sine of 34 degrees is .56 so when new figure t he hypotenuse of our triangle – which is the square root of ( 64 x 64) + (96 x 96) = 115 inch
diagonal weight transfer is the left rear wheel weight x Gs x CGht / 115 x sine A= 66#
we need to have spring rate of 555# + 66# = 621# up front.
You have 700# front springs. If we find the true wheel rate we get your motion rate of .765 x spring rate = 535#
You have a 355# front ARB + 535# + 535# = 1425# front end to counter 621# coming forward..a little stiff I think.
out back we have 211 pounds being slung around. Total weight transferred under 1.15Gs is 832# – 621# coming forward = 211#
we have a rear ARB of 271# plus 200# rr spring..again a little stiff.
One more huge wrinkle. The above diagonal weight calc is a little heavy because your have a REAR ARB. I would not worry too much about the impact of this until we get to where we are fine tuning the set up.
This is a formula for ball park figures on the springs and ARB. Intuitively, my gut tells me the ARBs and the springs are way to stiff.
I do not know the method you calculated the front motion rate or is you are running coil overs or traditional A-Arm and coil springs? Also we should find true CG height..
But still looks too stiff any way you look at it.
  • #592
Ranger Mike;
Thanks for the affirmation on the car being too stiff. Wouldn't the MR be applied to the bar also since it is not being applied directly to the outer ball joint pivot point? Using what you did in your reply, how would you select springs and bar(s) for that example if you had to start from there? Is there a general guide for how much spring versus how much bar to use? This is kind of like asking a magician how he does his tricks. I appreciate your time and patience. Thanks again, Dave
  • #593
i am in Detroit , I do not have my notes but if I remember correctly, the ARB is figured by diameter, length and length of the arm to get one rating. I forget the exact formula but I think you have to multiply the modulus of elasticity of the steel ( 500,000) in there some where. As far as the springs vs ARB,,,I wrote a lot about the BBSS big bar soft spring set up. If I remember the figures this morning when I did the calc, you need around 300 #springs and 200# bar..but..that did not take into account the rear ARB. In rear maybe 150# spring and 100 # bar..i am not sure about your rear motion rate of 1...have to see the dimensions,,Don't forget the more gas you burn off he less weight is coming to the front and the more the car will push. The closer you can get the ARB to the same rate as the springs the better handling it will be.
  • #594
smithdl4 said:
Ranger Mike;
For a pure lateral acceleration analysis have a look at this tool. You'll need to shift the defaults around quite a bit, but I think you have enough information to make use of it.
http://blackartracing.zxq.net/Load Transfer 2.php
  • #595
Ranger Mike said:
Well Thanks for the nice words, Smith. At first glance you have way to stiff springs and ARB...
Might need to clash swords with you again on these...
I am still not quite understanding your concept of diagonal weight transfer if it is being applied to pure lateral acceleration.
Why is this weight/load coming forwards? At 1.15g we assume pure lateral acceleration, and under any combined lateral and longitudinal acceleration both values must reduce to stay within a circle relating to that 1.15G maximum (the friction circle). IOW, you cannot be generating 1.15g in the Y direction AND 1.15g in the X direction at the same time, so the load on the outside front as calculated here is going to be more than the car will ever see in reality.
  • #596
Kozy I absolutely agree with you on the Gs. but...as I have said from the start.
.this is simply a method to get close to proper spring set up..not to be a blessed algorithm ..never meant it to be...
and the 1.15 G is not absolute as tracks differ..just a useful baseline
As you intimated to me the true diagonal weight transfer is complex..add to this the driver influence is all over the map due to tapping the brake pedal thus impacting the diagonal weight.
I use this as a start point...as long as all are aware of this it can be useful.
  • #597
I guess as a first pass kind of thing it works well as it's really adding a nice factor of safety. If you can hold that figure then you're not going to get into any trouble. Just seems a very different approach that is all, but then I guess I have to remember that I'd be coming from the angle of having penned out all the algorithms...
For a clean sheet I would probably start with with working out the ride frequencies.
Start out with a target hz of 2x lateral acceleration in G. So 1g = 2hz.
From that, figure out the load transfer and roll angles using the app.
Add in the bar specs, and tune to get the desired roll angle and load transfer distribution.
I've updated my app to display the break down of the load transfers, geometric, unsprung and elastic, as well as the distribution F/R. I would be interested to hear your thoughts on it.
My take on Smith's situation:
The front ride frequency is 2.5hz, the rear is 1.7hz.
Without any RC effects or bars, that puts the car at about 67% front roll stiffness and 59% front load transfer at 1.15G.
Front load transfer 549lbs, rear 284lbs of which 524lbs and 259lbs is elastic respectively.
Putting 524lbs into a 403lb/in wheel rate gives 1.3" deflection up front and 259lbs into a 200lb/in wheel rate also gives 1.3" wheel deflection at the rear.
Thus the chassis roll angle over a 64" track is 2.3°.
The springs alone look to be 90% of what you need.
I am not really sure on how the bars are rated though, to assess their effect on things. Is that rating per degree of roll, or per degree of twist in the bar?
  • #598
Kozy;
As I understand it the bars are rated in LBs per 5 degrees of twist per their manufacturer. Also, I think the wheel rate for both ends would be smaller as the springs are canted over 9 degree which changes the actual spring rate the suspension sees, correct?
Ranger Mike;
The rear has an MR of 1 due to its construction. It is an SLA IRS. The spindle is designed to have a bolt that runs through the bottom that captures the coilover shock, the outer spherical bearing, and the toe control arm and is parallel to the chassis (or pretty much). My question about bars was not on how to compute their force but their force applied to the suspension. It attaches at the same point on the suspension as the spring and since it is a spring also it just seemed to me you could not use the full rate but would need to multiply its rate by the same MR to arrive at a reduced rate like the spring. Maybe I'm just over analyzing.
Gentlemen;
Thank you both for taking the time to answer my questions as I try to really understand what's going on with suspensions. Dave
  • #599
Yes the bar gets its force reduced by the installation ratio the same as the spring does.
Still a little confused about the rate though. If it is 355lb/5degrees, that would suggest that the arm length has not been accounts for correct?
My calculations on bar rate take the diameter, length and arm length to give a rate in lbs per inch deflection at the end of the arms, which is directly comparable with the coil spring rate.
  • #600
Kozy..
I agree on ARB rate. There are numerous applications. Hollow and solid and many types of linkage. My assumption is the driver knows the ARB rate as hooked up on the vehicle. Ref the calc on weight..please bear with me..you say we have 524# weight transfer to the front..right?
Smith.. thank you for the clarification. Also if you note the attached pic on prior page the spring angle mount correction factor is there ..pretty small for 10 degrees.
  • · Replies 20 ·
9K
  • · Replies 49 ·
