How does radiation cause damage in cells?
  • Thread starter Thread starter madcat8000
    Method Radiation
The discussion centers on the mechanisms of radiation damage, particularly the role of water in forming radicals that cause cellular harm. It is suggested that most radiation damage occurs indirectly through interactions with water, leading to reactive oxygen species that inflict damage on DNA. This contrasts with the direct effects of lower-energy radiation, like UV, which can cause specific DNA alterations such as thymine dimers by exciting nucleotide bases. Higher-energy radiation, like gamma and X-rays, is noted for causing more severe damage, such as chromosome breakage, primarily through the generation of oxygen radicals. While the consensus leans toward indirect damage via radicals, it acknowledges that direct interactions with biomolecules can also occur. The discussion highlights the complexity of radiation effects, suggesting that the type of radiation influences the primary damage mechanism, with both direct and indirect pathways contributing to cellular stress and mutation.
madcat8000
I recently read in a book by a trusted author that most all of the damage done by radiation was into form of its interaction with water therby forming radicals that then proceded to do the damage.
Is this "in general" true and other books that attribute different actions with different forms of radiation were oversimplifing the details?
One memorable example was a microbiology textbook that associated UV radiation with small chincks and dimmers in a chromosome, while stateing that gamma radiation was far more dangerouse as it split the DNA completely into two pieces making the damage nearly unrepairable unless the cell was lucky enough to have a repair molecule working at that spot at that time. Aparently (and logicly) after a few seconds the ends of the DNA hit by gama radiation would be so far apart there would be no way to reconnect them.
However after some reflection the idea that radation does damage directly is a bit silly. Tons of water in a cell, far more likely to hit that imho.
Well thanks for reading this, maybe someone with some physics knowledge can speak authoritatively on this because id really like to know.
Biology news on Phys.org
There's probably a mixture of both mechanisms in action and the mechanism likely depends on the specific type of damage as well as the type of radiation.
For UV damage to DNA such as thymine dimers, I think it's likely that the nucleotide bases themselves absorb the UV radiation, which puts them into an excited, unstable chemical state allowing them to react with nearby bases to form dimers. In the case of chromosome breakage due to x-ray and gamma radiation, however, I would agree that the generation of reactive oxygen species is most likely mechanism.
If one wanted to generalize, I think that lower energy radiation (e.g. UV) is more likely to cause damage to biomolecules through direct absorption by the biomolecules whereas higher energy, ionizing radiation (e.g. x-ray and gamma) are more likely to cause damage via exciting/ionizing water molecules.
Ok I can roll with that. So in general radiation does damage via oxygen radicals but this doesn't preclude that "events" will happen in whitch occasionaly the damage is done directly...and the POV depends on whitch is more important. Oxygen radicals add to the overall stress levels of the cell while in certain mutations it dose appear that there was a direct interaction with radiation. TYVM
https://www.discovermagazine.com/the-deadliest-spider-in-the-world-ends-lives-in-hours-but-its-venom-may-inspire-medical-miracles-48107 https://en.wikipedia.org/wiki/Versutoxin#Mechanism_behind_Neurotoxic_Properties https://www.sciencedirect.com/science/article/abs/pii/S0028390817301557 (subscription or purchase requred) he structure of versutoxin (δ-atracotoxin-Hv1) provides insights into the binding of site 3 neurotoxins to the voltage-gated sodium channel...
Popular article referring to the BA.2 variant: Popular article: (many words, little data) https://www.cnn.com/2022/02/17/health/ba-2-covid-severity/index.html Preprint article referring to the BA.2 variant: Preprint article: (At 52 pages, too many words!) https://www.biorxiv.org/content/10.1101/2022.02.14.480335v1.full.pdf [edited 1hr. after posting: Added preprint Abstract] Cheers, Tom
