Radio, in which parameter is the information?
Radio broadcasts transmit information through electromagnetic waves, utilizing modulation techniques to encode audio signals. The information is not solely in amplitude or frequency, as both parameters can vary; instead, it's the relative changes in amplitude and slight frequency variations that convey the data. Each FM channel occupies a frequency range, allowing for modulation within that span, while AM modulation varies the amplitude of the carrier wave to transmit sound. The discussion also highlights a typographical error in a referenced diagram regarding FM channel labeling. Understanding these modulation schemes is crucial for comprehending how radio signals deliver consistent audio content despite distance and obstacles.
Helicobacter
When I listen to radio, then I know that the radio gets the information from electromagnetic radio waves. But in which parameter is the information of the song/news/output/whatever included?
It can't be amplitude, since amplitude decreases with distance of obstruction, and the data most people receive is relatively identical.
it can't be frequency/wavelength, since every channel has a constant frequency assigned to.
In the USA, each FM channel actually spans a frequency range of 0.2 MHz. For example, a station that broadcasts at 90.1 MHz actually uses frequencies between 90.0 and 90.2 MHz.
http://www.fcc.gov/mb/audio/bickel/oddno.html
The diagram on that page has a typographical error. FM Channel 202 should be labeled as 88.3 MHz.
AM = amplitude modulation
FM = frequency modulation
Remember that the radio freq is a carrier wave. This means that the (AM)680kHz wave or (FM)107.1 MHz wave is modulated to provide a much lower normal humans range signal riding on top.
FM = the frequency of the carrier is modulated to carry sounds in the normal human range
AM = the amplitude of the carrier is modulated to carry sounds in the normal human range
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
