Radio Wave Propagation: Effects of Metal Objects
Radio waves propagate around metal objects through reflection, refraction, diffraction, and scattering, with effects varying based on the wavelength of the signal. A mounting screw obstructing a GPS antenna by 2-3 cm may cause diffraction if its size is similar to the wavelength, while larger screws create a shadow effect. Generally, unless the screw is significantly large compared to the wavelength, it should have minimal impact on signal quality. The discussion emphasizes that typical scenarios will not lead to significant interference. Understanding these principles can help in assessing the potential effects of obstacles on radio wave propagation.
barry.haworth
Hi I wonder if anyone could advise how a radio wave would propagate around a metal object? Basically, I have a GPS antenna and due to mechanical issues the antenna is obscured by a mounting screw that sits in front of the antenna by about 2~3cm. I understand that the radio wave would become reflected/refracted/diffracted/scattered to some greater or lesser degree and is wavelength dependant. I wondered if anyone could advise how much an effect this screw would have and advise any approximations or assumptions that could be made?
Many thanks
Science news on Phys.org
Welcome to PF;
Much the same way a water-wave does.
Many thanks
Diffraction effects are important if the screw is similar in size to the wavelength of the signal.
If the screw is large compared with the wavelength, then you get more of a shadow effect.
Unless you are very unlucky, or you've left something out, the screw should have almost no effect.
Thank you for your reply Simon, very helpful!
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
