Radius of curvature formula derivation
The radius of curvature for a curve defined by y=f(x) is expressed as [f''(x)/(1+f'(x)^2)]^(3/2). A user requests a clear derivation of this formula. The discussion references the curvature of a vector function, defined as κ = |r' × r''| / |r'|^3. To derive the formula, one should set r = xi + f(x)j and simplify the expressions for r' and r''. The conversation emphasizes the importance of understanding the relationship between curvature and the tangent vector.
chandran
for a curve defined by y=f(x) the radius of curvature is defined as
[f""(x)/(1+f"(x))] power 3/2. I need a good neat & understandable derivation for that. can anybody show a web.
Mathematics news on Phys.org
Differential Geometry of Curves
I don't like the format of the forum reply, so click on the following link to view your derivative: DGC.
Well first understand that curvature for a vector function is given by:
\kappa=\frac{|\mathbf{r}'\times\mathbf{r}''|}{|\mathbf{r}'|^3}
Now, let r = xi + f(x)j and simplify. To prove the first formula \kappa, use the following fact and compute r' x r''. The answer should be clear from there.
\kappa=\frac{d\mathbf{T}}{ds}
\mathbf{r}'=\frac{ds}{dt}\mathbf{T}
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
