Random Photos
  • Thread starter Thread starter Point Conception
    Photos Random
3,891 replies · 243K views
Today I found out how this strip of grass and weeds gets mowed. It contains a drainage ditch, and runs in front of a vacant lot along one side of the street a couple of blocks from my house. I've never seen this particular device before. The operator has to make a couple of passes in order to do both sides of the ditch.
At first I thought it was a city employee, but the vehicle doesn't have the city's logo on it, so now I suspect the property owner must have hired the guy.
Reply
Here in Montana that's how the state and county crews mow, what's different in your picture is that I don̓t see any caution or warning signs to warn passing motorists and pedestrians. Those mowers will chop off a 3 to 4 inch branch as easily as it will cut a blade of grass, not to mention launching a piece of said branch at lethal velocities. I never see them operating without some type of warning, too much liability. I would assume the operator is a private contractor as most State, County or City departments are very particular about liabilty and insurance. The other clue would be, did the mower only mow the strip in the photo or continue on down the road like a normal city crew would do, completing the area in sections.
Could you tell what that black box thingie is in the front of the tractor?
Counterweight most likely, along with the rear wheel weights they are important for stability on uneven surfaces when the mower boom swings. It could also be a hydraulic fluid reservoir which in itself would make a good counterweight.
Reply
It looks like there may indeed be a counterweight black box thing to the driver's left, but a counterweight on the front would have to be for a heavy appliance on the rear...
Reply
Yes, upon zooming the image I see that the box on the drivers side is definitely the Hydraulic fluid reservoir, that means the box on the front is a counterweight to offset the mowing attachment. (although it could be a beer cooler) :wink:
Well, it's just googlework, but apparently this mower is not back, but side mounted. The black box on the other side is the alternative mounting point, while the front monstrosity is the hydraulics pump/tank.
Since it's side mounted, the counterweight is on the other side: it is attached to the rear wheel :smile:
Ah, I wondered what that was. Good catch!
And I like the beer cooler idea better for the front box. :smile:
Good googlework, Your correct on the boom mount location, I didn't notice until looking closer. One thing that threw me was that I didn't realize how small the tractor was until looking at the operator in the cab. The front box in that case, very well could be a PTO pump, reservoir. the black box on the right side with the yellow stripe in the top corner is also a main Hydraulic fluid reservoir, but an auxiliary tank would make sense if combined with a front PTO pump. The mower attachment needs a large capacity reservoir to maintain flow and temperature control. If @jtbell gets another chance to get a closer look that would clear up that question, hard to tell as the resolution blows up pretty bad when trying to see details. Pardon the delay in my reply's, having a bad day with connectivity issues.
I didn't hang around long enough to see what he did at the edge of the vacant property. I'm pretty sure he must have stopped there, because homeowners are responsible for maintaining the city-owned strip of land between their property line and the street. It might look odd if the city did it, but on a different schedule from all the homeowners. Of course, we all do our lawns (or have our lawn guys do them) on different schedules anyway...
Reply
Hi @jtbell, Thanks for the answer. The tractor could be a new piece of city equipment or a private contractor, hard to tell. If you get a chance to see the tractor again, there is a question about the black attachment on the front of it. Is it a hydraulic reservoir/pump assembly or a counterweight?
It could be either one and it's hard to tell from the photo that you posted, If you get a chance to check that out it would be greatly appreciated, although not a critical point it is a curiosity that was being discussed. Thanks again, Scott
While walking my dog I noticed that...
The Flower Boat is Blooming!
They might want to shake off the cover.
Reply
  • Haha
  • Wow
Low tide, Pattaya bay. South end
Reply
Looking North from North end of bay.
Reply
Same sunset : NW and SW views
DennisN said:
I'm actually thinking of going back to Copenhagen soon, and bring a bike with me on the train and then bike around in the city to places I haven't been to.
I'm thinking of maybe going to the Little Mermaid (which truly is small :smile:, I've been there) and try to take some kind of unusual photo of her if possible (probably in the late evening and with some lighting, or something, I haven't decided yet :smile:).
Yes, the little mermaid is very photogenic. Which might be a way of saying when you go there she is quite disappointing after the photos. (People do often say so.) But if you're going there as a photographer, not just a tourist, you have I hope a lot of time to hang around, consider the various angles of the Sun during the day and the effects achievable with your special Russian lenses etc.
All the better if you were going there with your bike. Not that you need to take a bike to Copenhagen as you already know - I don't know any city so totally dominated by bikes – not even in the Netherlands did I ever see anything like it. But if you have some special bike of your own all the better. Just don't forget and leave it there like Mr Wheeler.
Reply
Andy Resnick said:
Lucky shot of the day:
A beautiful bird and a beautiful photo! Was it taken with a manual lens or an autofocus lens? And was it a tele or a zoom lens?
I've made a map with places in Copenhagen to visit/photo locations, for instance:
Nyhavn, the nice old waterfront district (I've been there before, but it was probably twenty years ago):
Photo by Vincents productions (Creative Commons, Wikipedia)
Niels Bohr Institute (founded by Niels Bohr) (I've never been there):
Photo by Thue, public domain
Rundetaarn, the 17th-century astronomical tower (I've been there, but I haven't photographed it):
Photo by Avda (Creative Commons, Wikipedia)
Copenhagen Botanical Garden (I've never been there):
Photo by Henrik Jessen (Creative Commons, Wikipedia)
Reply
Street flower (shot during a short lens test yesterday):
Plants escaping the fence (another test shot):
I also recently found a new fun glass toy in a second hand store just a block away (this was not the lens I tested above). It's a fast 40mm, which is a pretty uncommon focal length. It's a quite good lens, and the price was merely $12, so of course I bought it. :smile:
Konica Hexanon AR 40mm f/1.8
Reply
Beautiful Black on Black 🖤🖤🖤
Reply
Photo by Thue, publ
I was there mainly for about a week sometime around roughly the same year as you. (Very much later than Mr. Wheeler).
Copenhagen is outstanding for design
Reply
A happy lamp :smile: :
Reply
  • Love
A couple of days ago I heard a complaint from one of my cupboards.
It was my macro lens which said "You bought me and tried me at home, you liked me, but you have never took me out anywhere. Why?"
So I took the lens out for a walk.
We found a daisy...
...and then a dandelion seedhead...
...and while we were sitting in the grass we noticed there were bees feeding on flowers, so we took a shot at those, even though we hadn't planned it. It's not easy with a manual lens, you've got between ca 1 - 3 seconds to focus and shoot before the bee takes off (as a result only about 3 out of 45 photos had reasonable focus :smile:).
And when we got home and looked at the photos, we noticed we had accidentally shot an ant climbing up a violet flower:
I think the lens is promising also for ants.
I focused on the flower (down below) and not the ant (since I didn't know there was an ant), so with better focus next time, more ant details may come out. :smile:
Lens used: Canon nFD Macro 50mm f/3.5.
Reply
  • Love
Thanks! Manual focus lens (800mm, shot at f/8). I was standing about 20 feet away from the hummingbird (female ruby-throated hummingbird, FWIW) and it flew off right after the photo.
Reply
That *is* a great lens, I have one as well!
Reply
