Point Conception
- 1,937
You mean "mirrored vertically", not "upside down". What happens if you rotate the original image 180 degrees to make it "upside down"? Does it still show the same illusion?jack action said:The same picture of spilled water, one right side up, the other upside down.
The funny thing is that the "carved" effect only appears when the two images are shown side-by-side.
The right image is the left image rotated 180° only. (Look at the darker bottom-right corner becoming the top-left corner to convince yourself.)berkeman said:You mean "mirrored vertically", not "upside down". What happens if you rotate the original image 180 degrees to make it "upside down"? Does it still show the same illusion?
When I rotated the image by itself, this is when I noticed that I couldn't see the illusion and I was kind of deceived: Maybe the original I saw was a trick shot? But when I put it side-by-side with the original on the post, it appeared immediately. And when I went back to look at the rotated image by itself on my computer, the illusion was still there!BillTre said:Covering one half or the other should make that effect go away, but that didn't work for me. Maybe the established impression of the direction of illumination sticks around a while.
Love these photos…..amazing & artistic….morrobay said:Special effects: flashlight on foto Jomtien beach about 3 years ago, unfortunately - So far...View attachment 320219
BRRRRR ... close that door, dammit !Flyboy said:When it’s -30°F with wind chill factored in, and you have to clear the driveway because the HOA-contracted snow removal folks do a terrible j
There’s actually a glass outer door there that’s keeping the worst of it out.phinds said:BRRRRR ... close that door, dammit !
nsaspook said:Rear ended his car!
One of my neighbors (in Eugene) has a metal roof. Ice started melting under it and it slide off and took her gutter with it.nsaspook said:A few days later.
Having clear skies for 28 nights in a row is the really impressive part.fresh_42 said:
And I agree with @collinsmark.collinsmark said:It's absolutely fine to process your photos.It's not cheating, it's doing your due diligence.
Rive said:Yep, flash. Thanks.
A lucky one:
An 'usual' one:
What flash does is, that the background is lighter, overexposed. The cat is the same - black
Both in- and outdoor, but these lazy moments are indoor exclusive...DennisN said:The best, I think, would be to photograph the cat outside in broad daylight, but maybe it's an indoor only cat, I don't know?
