What is the solution for a one-dimensional random walk in potentials?
The discussion focuses on a one-dimensional random walk constrained within the interval [0,1], influenced by a probability distribution p(x) that determines the likelihood of moving left or right. The walker starts at x=0.5 and aims to capture the steady-state distribution of its position over time. Participants suggest modeling the problem as a Markov chain, highlighting the need for a discrete step size to ensure the walker remains within boundaries. A differential equation approach is mentioned, but challenges arise due to singularities at x=0.5. The conversation concludes with curiosity about the physical implications of this model.
blue2script
I have a problem concerning a one-dimensional random walk in potentials. Assume a one-dimensional space [0,1] and a probability distribution p(x). At every point x we have a probability p(x) to go left and 1-p(x) to go right. Assume some smooth distribution of p(x) with boundaries p(0) = 0 and p(1) = 1. Now begin a random walk at x=0.5 with some step-size dx (e.g. d = 0.01) and capture the position of the walker at every time-step t. The boundary constraint assures that the walker remains inside [0,1].
I would assume that after sufficient time steps I get a steady distribution of the position of the walker. This would be equivalent to the probability distribution of finding the walker at some point in the potential.
However, I have yet no idea how to calculate this distribution from some given p(x). I tried to set up a differential equation using the fact that in the steady case the flow from point x to x + dx and back must be zero. However, I would get a pole at x = 0.5 which is pretty useless. I can post the calculation if someone is interested.
I would be glad for every hint how one could solve this problem. Thanks in advance!
Blue2script
Mathematics news on Phys.org
I assume a fixed step size ; we can let it tend to zero later.
Firstly, the boundary conditions don't warrant that the walker won't trip at 0 or 1 ( for instance, take d=1/300). If you want that constraint with initial position =1/2, the step size must be 1/2n for some integer n , making the walk discrete.
In such a case, this can be modeled as a Markov chain with 2n+1 states ( x=1/2 & other 2n possible positions ;with transition probabilities p(xn)&c. at each state. The limit of the transition probability matrix yields the long run probabilities.
Finally,letting d->0 gives a continuous time Markov process.
P.S. : Is this a model of any physicsl phenomenon? I ask out of sheer curiosity.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
