Rate of Change: Show dh/dt Proportional to h^(1/2)
The discussion centers on a rate of change problem involving fluid dynamics in a cylindrical tank. The fluid's outflow rate is proportional to the square root of the remaining volume, leading to the differential equation dh/dt = -kh^(1/2), where k is a positive constant. The relationship between volume and depth is established using V(t) = πR²h(t), allowing for the substitution of variables. The key takeaway is the application of the chain rule to connect static geometric equations with dynamic rates of change. Understanding this relationship is crucial for solving similar rate of change problems effectively.
padraig
Sorry to bore you all with this rate of change question, I really hate this area of maths and struggle to get my hea round it. Here it is, I'd be greatful for any help you have to offer:
Fluid flows out of a cylindrical tank with constant corss section. At the time t minutes (t is greater of equal to 0), the volume of fluid remaining in the tank is V m^3. The rate at which the fluid flows, in m^3min^-1, is proportional to the square root of V. Show that the depth h metre's of fluid in the tank satisfies the differential equation:
dh/dt = -kh^(1/2) where k is a +ve constant
Cheers
Pat
Mathematics news on Phys.org
dV/dt=-aV^(1/2), by assumption.
V(t)=pi*R^(2)*h(t)=b*h(t) (where R is the radius)
Rearranging a bit, and introducing k yields the desired result
thanks v much, great help
Pat
In other words, the whole point of "rate of change problems" is to use a static equation (typically a geometry formula or something like that) that has no time variable, t, in it and then use the chain rule to differentiate both sides of the equation- giving a formula connecting the rates of change of the quantities.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
