Rate of effusion dependance on pressure
The rate of effusion is directly proportional to the mean speed of gas molecules and inversely proportional to the square root of their molar mass. While it seems that the rate should also depend on pressure, the relationship is clarified through the statistical mechanical equation of state, P = nkT. This equation shows that an increase in pressure leads to a higher number density of molecules, which enhances the rate of effusion. Therefore, the rate of effusion increases with pressure due to the increased number of molecules available to effuse. Understanding this relationship helps clarify the apparent contradiction regarding pressure's effect on effusion rates.
jd12345
In my class rate of effusion was told to be directly proportional to the mean speed of gas molecules which is intuitive and i understand. RMS speed of molecules is √3RT/M
So rate of effusion is inversely proportional to sqaure root of molar mass
But i don't understand how rate of effusion is directly proportional to pressure
RT = PV
So RMS speed = √PV/M so rate of effusion should be proportional to square root of pressure right? But apparently its not, please explain me why
Thank you!
RT = PV
Thank you!
It makes more sense if you replace PV=RT with the statistical mechanical equation of state,
P = nkT. Then the number density (number of molecules per unit volume) is directly proportional to the pressure. The more molecules per unit volume, the greater the effusion through an opening.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
