Ratio for Kindetic and Potential energy
The discussion focuses on calculating the ratio of kinetic energy (K) to potential energy (P) in a block-spring system undergoing simple harmonic motion (SHM) at time t = 0. The ratio is derived using the equations for position and velocity, leading to the expression K/P = [tan(φ)]². Despite arriving at what seems to be the correct answer, the original poster reports that their answer was marked wrong, raising concerns about the required format for submission. Other participants suggest that sometimes correct answers may need to be presented in a specific form to be accepted. The conversation highlights the challenges of interpreting and formatting answers in physics problems.
Awer1
If the phase angle for a block-spring system in SHM is φ and the block's position is given by x = xm cos(ωt+φ), what is the ratio of the kinetic energy to the potential energy at time t = 0? State your answers in terms of the given variables.
x =xm Cos(wt + phi)
v = -w(xm)sin(wt +phi)
K = (1/2 mv2)
P = (1/2 m w2 x2)
dividing K/P = [v/wx]2
substitute v and x we get: [(-w(xm)sin(wt +phi)/(w)(xm Cos(wt + phi))]2
simplifying we get: [-wtan(wt + phi)/w]2 = [tan(wt + phi)]2
at t = 0 we should get the following: [v/wx]2 = [tan(phi)]2
The answer is marked wrong, am I interpreting the question incorrectly? I know what ratio is.. and ratio for Kinetic energy and Potential should be K/P right?
you are absolutely right ! its odd that it is marked wrong .. maybe you should change the form of your answer? try different form maybe that will work ..
oh good I thought I was going crazy. I was only allowed three attempts. so I used three different formats that were all the same thing.. still marked wrong.
it happens, sometimes you have the right answer but i.e you have to express it in a certain form or in a certain sigificance .. :) anyway, don't worry you had the right answer ..
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
