Solve Ratio Problem: Minimum Number of Oranges in a Box | 50+ Fruit Pieces
  • Thread starter Thread starter tomtomtom1
    Ratio
The ratio problem involves determining the minimum number of oranges in a box containing apples, oranges, and lemons in a 5:3:1 ratio, with more than 50 pieces of fruit. The total number of fruit must be a multiple of 9, and the smallest multiple greater than 50 is 54. This means that if there are 54 pieces of fruit, the number of oranges is calculated as 3 times the factor used to reach that total, resulting in 18 oranges. The initial calculation of 17 oranges is incorrect due to not considering the requirement for the total to exceed 50. Therefore, the correct minimum number of oranges is 18.
tomtomtom1
Hi all
I have a ratio problem which i was hoping someone could help with.
The question is this:-
Barry bough a box full of fruit. The contained some apples, oranges and lemons in the ratio 5:3:1. Given that there were more than 50 pieces of fruit in the box work out the minimum number of oranges in the box.
I do the following:-
5+3+1=9
(50/9)*3=16.666..
You cannot have 0.666 of an orange the answer is 17.
But this is wrong the answer is in fact 18 according to the answer sheet but WHY?
I know it has something to do with the statement "more than 50 pieces" but i cannot figure it out.
Can someone help
tomtomtom1 said:
Hi all
5+3+1=9
(50/9)*3=16.666..
Can someone help
Assume there are N pieces of fruit altogether. How many pieces of each type would there be?
If you were to have 5 apples, 3 oranges and one lemon, you would have 9 fruit.
So, you can only have n * 9 fruits where n is a positive integer.
Can you work out the smallest value for n such that n * 9 > 50?
What does that tell you about the minimum number of oranges?
Another, more "algebraic" way to do this is to let "x" be the number of lemons. Then the number of oranges is 3x and the number of apples is 5x. The total number is x+ 3x+ 5x= 9x so the number of fruit must be a multiple of 9. The smallest multiple of 9 larger than 5 is (9)(6)= 54.
The answer is 6, so 6 * 3 = 18. got it thanks
Past Exam Questions on Ratio
Hi i found a past exam ratio questions on line and attempted to do them, i have attached my results, can anyone spot any mistakes?
Thanks
First, no the answer is not 6. The answer is 18. Try not to take x for the ANSWER whenever you solve for x.
Second, I think you should open another topic to place that PDF.
Third, question 17 is correct to me.
