RC Circuit - Charge on Capacitor
The discussion revolves around an RC circuit involving a capacitor and resistors, where the original poster seeks to determine the charge on a 4 μF capacitor given a battery with an emf of 20 V and internal resistance. The challenge arises from the presence of a steady current in the circuit, complicating the application of standard charge equations.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to apply the equation Q = CE but expresses difficulty due to the ongoing current. They question the applicability of Kirchhoff's laws given the number of unknowns. Some participants suggest determining the voltage across the capacitor to find the charge, while others explore the implications of current flow and voltage division in the circuit.
Participants are actively engaging with the problem, offering insights into voltage calculations and the relationships between resistors in series. There is a recognition of the voltage across the capacitor as a key factor, and some clarification is sought regarding the configuration of the resistors in relation to the capacitor.
There is an ongoing discussion about the assumptions regarding current flow through the capacitor and the implications for voltage calculations. The original poster notes a lack of time information, which adds complexity to their analysis.
calvert11
In the figure below the battery has an emf of 20 V and an internal resistance of 1.
Assume there is a steady current flowing in the circuit.
http://img48.imageshack.us/img48/9211/44724253.gif
Find the charge on the 4 μF capacitor.
Answer in units of μC.
Q = CE
No time is given, so I can't use the equation for charge as a function of t.
From the figure, Resistors 1 and 5 seem to be in series. The circuit can't be simplified further.
But the charge on the capacitor can't be Q=CE since a current is still flowing. Can I have some advice on how to get started?
I tried using Kirchhoff, but I didn't get anywhere. I think I have too many unknowns, not enough equations (am I wrong?)
I'd be very grateful for any help.
It's true there is current flowing in the system, but there is still a voltage across the capacitor.
Q = V*C
Determine then the voltage across the capacitor and the charge on the capacitor will be known.
Q = V*C
Okay, using I= V/R the current for equivalent resistor 6 is 3.333 and for resistor 8 it's 2.5.
Voltage at resistor 5 is 3.333*5=16.6665
Voltage at resistor 8 is 2.5*8 = 20
Voltage through the capacitor is 20 - 16.6665 = 3.3335, which is wrong.
What about my approach is incorrect?
For 1 thing V = I*∑R = 20/14
That makes Vc = 8*20/14
Q = V*C = 4μf*160/14 = 640/14 μf
That's incredibly helpful. But to clarify, resistors 1, 5, and 8 are actually in series because no current flows through the wire with the capacitor?
There was current when it charged of course. But basically with the capacitor all you are concerned with is its voltage. And that is determined by the Voltage Divider of the resistors in series.
