RC Circuit - Currents at Timed Intervals
The discussion focuses on calculating the time it takes for the current in an RC circuit to drop to 0.37 times the initial current after closing a switch. The user calculated the time constant as 5.175 seconds but struggled with the equation to find the specific time when the current reaches 0.37 of its initial value. They noted that the notation I(t) represents the current at time t, not a multiplication of current and time. The conversation emphasizes the importance of understanding the relationship between initial current and the exponential decay of current in the circuit. Clarification on the interpretation of current values and the application of logarithms is also sought.
purduegirl
An uncharged 1.15 uF capacitor is in series, through a switch, with a 4.50-M Ohms resistor and a 24.0- V battery (with negligible internal resistance.) The switch is closed at t = 0 and a current of Ii immediately appears. (Which I calculated to be 5.33 uA.) How long will it take for the current in the circuit to drop to 0.37 Ii?
V = Voltage of Battery - I*r (This will not apply here because r is negligible)
V = IR
I(t) = Voltage of Battery/Resistivity*exp^(-t/time constant)
Time constant = RC
4.50 MOhms = 4.50E6 Ohms
1.15 uF = 1.15E-6 F
I calculated the time constant and got 5.175 s. I plugged in the information above into the current based on time equation, but couldn't solve for time.
Can you show how far you got? What part were you stuck on?
I can try.
(.37 A)(t) = 24.0V/ (4.50E6 Ohms)*exp^(-t/5.175 s)
.37 A(t) = 5.33E-6 V/Ohms*exp^(-t/5.175 s)
Here's where I have trouble. I know by using ln I could cancel out the exp. However, by having to apply it to both sides, I would get ln(.37 A)(t).
I(t) does not mean I times t; I(t) means "the value of I when time = t". (It also indicates what I depends on.)
So I(2) is I when t=2.
So the t should not be on the left hand side.
However, they don't say that the current is 0.37; they say the current is 0.37 Ii (that is, 37 percent of the initial current). Can you see that you did not have to calculate the initial current?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
