MHB How many times should the value of inputCount be read?
  • Thread starter Thread starter Chrisanchez
    Format Integers
The discussion centers on a coding issue related to reading an integer input count and subsequently reading that many integers to output them in a specific format. The main problem arises from the code's logic, which leads to the last integer being repeated multiple times in the output. The user is confused about how many times the program should read the input count based on the problem statement, which specifies reading an initial value for `inputCount` and then reading that many integers. The user believes the program should read the input count only once and then read the specified number of integers, but the current implementation incorrectly reads the last integer repeatedly. Clarification is sought on the interpretation of the problem statement, particularly regarding how many times `inputCount` should be read and the expected output format. The user emphasizes the need for precise quotes from the problem statement to support their understanding of the requirements.
Chrisanchez
First, read in an input value for variable inputCount. Then, read inputCount integers from input and output each integer on a newline after the string "value - ".
Ex: If the input is 2 25 55, the output is:
value - 25
value - 55
Code:
#include <iostream>
using namespace std;
int main() {
int inputCount;
int i;
cin >> inputCount;
for(i=0; inputCount > i | | inputCount < i; ++i){
cin >> inputCount;
cout << "value - " << inputCount << endl;
return 0;
I'm having trouble figuring out what I'm doing wrong, I able to get the output that I wanted but it keeps repeating the last output that is needed. for example the output that I'm getting is "value - 25 value - 55 value -55 . . ." and it keeps repeating the last output.
Technology news on Phys.org
How many times should the program read inputCount according to the problem statement? How many times does your program read inputCount?
It should read inputCount 2 times and output the values after the initial stated amount of times. for example the values are 3, 20, 26, -20. So it should read the 3 as how many times down the list it should output, for example the code output should be 20, 26, -20. But my code for some reason, i do not know, will read the last value, -20, and continue to repeat it for more than 10 times when I need it to read it once.
Please convince me that the problem statement really says this. Show me the exact quote and explain why you think the program should read the value of inputCount two times. I suggest using short and clear sentences.
This is the question that they are asking me:
value - 25
value - 55
I have already read the problem statement in post #1. There is no need to repeat it. I asked you to provide a small quote that says that the value of inputCount should be read twice. Do you agree, for example, that the phrase 'output each integer on a newline after the string "value - "' has nothing to do with reading inputCount? Then why do you quote it? Please quote only the relevant part that says how many times inputCount should be read. Also describe how you interpret that quote, why do you think it says what is says.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
