Fortran Read start: end of file error in fortran
The discussion revolves around a programming issue related to reading multiple files in a loop. The user is encountering an "end of file" error when attempting to read the 40th file, which contains 1163 lines, while all files are confirmed to open correctly. The main concern is that the code attempts to read up to 2000 lines from each file, which is problematic since none of the files reach that length. Suggestions include disabling error checking on the read statement or adding a header line to indicate the number of data lines in each file. Additionally, there is a recommendation to write out the read data immediately to verify what is being processed. There is also a note questioning the use of the format specifier '51a', suggesting that it might need adjustment for compatibility with the compiler.
agalya
Hi all,
do i = 1, 79
open(2,file=afiln(i),status='old')
do k = 1,11
read(2,'(51a)')astr1
enddo
do j=12,2000
read(2,22,end=23,err=23)iyr,imn,id,ih,imt,flx
write(7,*)i,j
obstim = float(id)*1440.0+float(ih)*60.0+float(imt)
if(obstim .eq. pt(i).and. flx.ne.1.0E33)then
if(flx .ge. 1.0)then
write(3,*)afiln(i),j,imn,id,ih,imt,flx
endif
endif
enddo
23 write(*,*)i
enddo
In the above program I'm reading 79 files of different length, no file is 2000 lines length. but at 40th file (length 1163) it isays read start: end of file.
Can somebody please help me rectufy this problem
Thanks
Technology news on Phys.org
Are you sure that your files are opening correctly? I thought that I've tried opening a file via string array and it not working real well.
Also, you may have problems since the files aren't always at least 2000 lines. You are trying to read data 2000 lines down on each file, for which there may not be there.
There are two ways around this. First, I believe you can basically "turn off" the error checking on the file read. It's an argument in the READ statement.
The better way would be to include a header line in each file stating how many lines of data that file contains. Then, instead of looping from j=12,2000, you loop from j=12,n.
HI
Thanks for the reply, but none of the file is having 2000 lines(1450 lines only), up 40th file they go properly. I'm having problem for this file only(1163 lines). Dont understand why it is happening to this file alone since the "end" statement in the read works properly for other files.
* files are opening properly
thanks and regards
Directly after you read the file, write it out using the exact same code (substituting READ for WRITE) and see what files are being written. You need to find out exactly what's happening in the code, and that's the best way. Are you actually reading what you think you are?
agalya said:
Hi all,
do i = 1, 79
do k = 1,11
enddo
do j=12,2000
write(7,*)i,j
endif
endif
enddo
23 write(*,*)i
enddo
Thanks
Don't know what your compiler thinks of 51a format...
shoudn't it be 51a1 or 51a2 or 51a4?
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
Thread 'Project Documentation'
Trying to package up a small bank account manager project that I have been tempering on for a while. One that is certainly worth something to me. Although I have created methods to whip up quick documents with all fields and properties. I would like something better to reference in order to express the mechanical functions. It is unclear to me about any standardized format for code documentation that exists. I have tried object orientated diagrams with shapes to try and express the...
9K
9K
25K
