Is My Light Meter Reading in mLux or Lux?
The discussion revolves around the confusion regarding light meter readings, specifically whether they are in Lux or mLux. A user inquires about their light meter set to 2000, questioning the interpretation of a reading of 1253. Responses indicate that without additional details about the meter's make and model, it's challenging to determine the units accurately. It is suggested that if the meter is set to 2000 and the reading is 1253, it likely indicates 1.253 Lux, assuming the meter measures in Lux. Overall, more information about the device is necessary for a definitive answer.
otterandseal1
Hi, I'm studying physics and was wondering about the light meter I used. It was set to 2000 so I could get readings, instead of 2 because the readings wouldn't show. Does this mean my values I get from the light meter is in mLux (milli) or just Lux?
Science news on Phys.org
I am just guessing here because I don't have the manual that came with your meter. If your setting is 2000 and the reading is 1253, then it means 1.253 Lux.
Hi there, @otterandseal1
and welcome to PF :smile:
or 1253 Lux ... depends on what the units of the 2000 is
mate, you really need to tell us lots more info
Make, Model even a sharp and clear photo of the front of the unit would be extremely helpful
2000 means nothing to us if you don't tell us the unitsDave
Likes russ_watters
or 1253 Lux ... depends on what the units of the 2000 ismate, you really need to tell us lots more info
I don't have it with me. It's measured in lux. Theres a knob that turns to 2, 20, 2000, 20000
do you have a manual for it ?
if not, there's probably one online
it would seem that it measured 1253 lux, which is a pretty bright light source.
Just an aside for light sources, the avg data projector for a home or board room is from 1500 - 3000 lux
a good number are much higher 5k to 8k lux for larger auditoriums
so, till you provide more info, no one can help youDave
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
