Real Analysis: closed sets and limit points
Askhwhelp
For the following example:(if possible give example or just state impossible
1) a bounded subset A of R for which sup A is not a limit point of A. An example is (0,1) union {7}. will this work?
2) a finite subset A of R that is not closed
I think it is not possible. Please give some hints if you think there is an answer
1) works fine. For 2), can you think of a proof that nobody will be able to come up with an example?
Wait ... why is ##7## not a limit point of ##(0,1)\cup\{7\}##?
Since not all epilson nbhd of 7 intersects the subset other than 7 which violates the definition of limit
If a set has no limit points, then by definition it is closed.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
