Real Analysis Continuity problem.
quantchem
Show that |f(x) - f(y) | < |x - y| if f(x) = sqrt(4+x^2) if x is not equal to xo. What does this prove about f?
Already proved the first part. I am guessing that for the second part the answer is that f is continuous but I am not really sure how to show it. Please help.
Well, sure. It's continuous. What's the definition of continuity?
I did this :
let
|f(x) - f(y) | < epsilon and |x - y| < delta. then epsilon < delta and therefore for each epsilon > 0, there is some delta > 0 such that |f(x) - f(y) | < epsilon when |x - y| < delta. so f is continuous at y when x is in an interval where f is defined.
Is this sufficient explanation?
quantchem said:
I did this :
let
Sure. So given any epsilon, you can pick delta=epsilon and satisfy the requirements of continuity, right?
yup. thanks.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
